Old 01-16-2015, 10:11 AM   #1
21FBRS Instructions Missing
I just took delivery of a new 2015 21FBRS. No instructions or manuals for the power awning, slide out or power jack. I'm concerned about how to operate these "conveniences" in the event of an electrical problem. Anyone else not get this information in the instruction packet? Hints?
danking49 is offline   Reply With Quote
Old 01-16-2015, 10:13 AM   #2
MtnGuy's Avatar
I was lacking a bunch of information when we bought our camper. I contacted the dealer, told him what I wanted, and he got me the information. It should not be our responsibility to look up everything and go to the cost of printing it out.........let the dealer that.
Old 01-16-2015, 10:21 AM   #3
x2
I made sure I asked in PDI. If they didn't cover it, they should answer your questions now
2015 Ram 2500 4x4 6.4l with 2015 Sandpiper 25RLS
Wife, myself and 2 furry kids
Mountndream is offline   Reply With Quote
Old 01-16-2015, 07:26 PM   #4
There is a tool in the storage compartment for the slide. If you look under the couch you'll see the motor for the slide and should also see a receptacle for the slide too. Wind it in/out manually as needed.
My jack has a plug in the top. remove the plug and you'll see a bolt head. turn it with the correct size socket.
Can't recall the manual extension and return for the awning. I'll check my manual and get back to you if no one else answers before then. Edit: A manual is attached.
File Type: pdf Dometic Power Patio Awning 895(X)0(X)(X).400(X).pdf (763.0 KB, 40 views)
00buck is offline   Reply With Quote
Old 01-16-2015, 10:04 PM   #5
Thanks for the quick responses! Looks like I'll just need to buy a pull strap to manually roll up the awning.
2015 Flagstaff 21FBRS
2012 Silverado 1500 LT Ext Cab 5.3L 3.08
Blue Ox SwayPro 550
Old 01-16-2015, 10:20 PM   #6
This forum is a great source of information. You cad do a search of your model or go to the dedicated section for your make for info. Or just ask. Frogs are very helpful
2012 F250 6.2 gasser 373 rear
2013 Rockwood 2104S Mini Lite
Ole Buzzard is offline   Reply With Quote
Old 01-18-2015, 10:44 AM   #7
I did find the documents section on the Lippert site for their documents. Can't quite figure out which slide out is the correct one though. I'm assuming the Sofa Slideout is pretty close. Camper is back to the shop for a slide out adjustment (top was bowed out some at the top) and water system pressure check and re-winterization (the camper was delivered to me with a 4" block of ice in the freshwater tank). And no, I'm not a happy camper with this dealer.
Blue Ox SwayPro 550
Old 01-18-2015, 11:20 AM   #8
It sounds like your dealer is not doing a very good job. He should be able to atleast give you mfgrs and model nos of appliances attachments etc.. With those you can search this site or the net for manuals or info..we all have gone thru the samething with instructions. I have a 3"red notebook with manuals parts lists etc and about 30 links to posts on here that are model specific.
Old 01-18-2015, 07:43 PM   #9
Forest River RV - Manufacturer of Travel Trailers - Fifth Wheels - Tent Campers - Motorhomes
go to this address and copy what you need/want
the pages has all FR material
SPARKEY BOB
IBEW LU 613 Atlanta
Micro Lite 21 FBRS
Toyota Tundra
SparkeyBob is offline   Reply With Quote
Old 01-19-2015, 09:35 PM   #10
Slympicins's Avatar
Pretty much everyone on these forums has experienced one form of issue or the other. Search the threads and you will find it here.
Trust me when I say, as a TT owner, you learn quick.
Chuck and Joanne
2014 Flagstaff Super Lite Classic 27RLWS Emerald
2013 Dodge 2500 4x4 Laramie Crew
Equal-i-zer 1200/12,000 4-point WDH
Slympicins is offline   Reply With Quote
Old 01-21-2015, 10:41 AM   #11
I've managed to round up all the missing manuals online except for the slide-out; much in part to help from everyone here! Even FR said they didn't have a Lippert manual for the slide out in a 21FBRS. Hoping Lippert will respond to my email and send me something (nothing like it on their site currently).
Blue Ox SwayPro 550
Old 01-21-2015, 10:21 PM   #12
Did they say if it was a Schwintek slide?
Old 01-22-2015, 08:42 AM   #13
Nope, FR just said they did not have a manual for the 21FBRS slide. Looks to me like it is some version of their above floor slide system.
Blue Ox SwayPro 550
Old 01-22-2015, 12:58 PM   #14
Try a new post to see if anyone here knows.
Old 01-24-2015, 10:55 PM   #15
Last thought about your slide, try to find the controller. Mine is located in the front storage area by the water pump. That will at least give you a mfg of the slide. You may be able to figure out the slide model from the controller.
Old 01-25-2015, 06:44 AM   #16
Thanks! I hadn't considered that there even was a controller for the slide! I'll check that out as soon as all this ice and snow go away.
For what it's worth, overall I've found this trailer to be relatively well put together; definitely better than most of what I've looked at.
Blue Ox SwayPro 550
Old 01-29-2015, 02:48 PM   #17
No controller that I can find. Lippert did get back to me; but only to say they didn't know what FR used in this year's 21FBRS. One word for the RV industry; BUILD LIST by VIN. It would take all of two minutes to find a P/N, and manufacturer for every nut and bolt on my truck. Ughh.
Blue Ox SwayPro 550
Old 02-02-2015, 07:21 PM   #18
Well, here is the email I finally got from Lippert. Explains why there is no manual. At least I know how to describe it should I need support.
Dan
The slide system number is 275549/Wheel Well Slide. I can tell you that if we do not have a manual the manufacture will not have one either. If for any reason you will need technical assistance please do not hesitate to contact us at 574-537-8900.
Thank you
Angie Burns
Lippert Components-Parts Dept.
W:574-537-8900
F:574-534-7161
Blue Ox SwayPro 550
Old 02-02-2015, 09:10 PM   #19
Slympicins's Avatar
That's odd the manufacturer wouldn't have a manual. Why would that be?
Chuck and Joanne
Old 02-02-2015, 11:29 PM   #20
It's the world of RV manufacturing. From what I can determine, this particular slide is essentially and adaptation of their regular sofa slide with the drive motor mounted to the side of the wheel well.
I find it even odder that the FR manual that came with my 21FBRS doesn't even cover many of the features it has; black water flush and antifreeze inlet system for example.
Blue Ox SwayPro 550
