Old 03-28-2015, 02:34 PM   #11
As it turns out the motor is not moving, well, not much anyway. The problem was the mattress pad we added. It sticks out just far enough that it catches the slide, which added just enough tension the blow the fuse.
That small amount of rotation though does concern me. I tightened up those screw bolts a smidge but was afraid to put hardly any snugging torque.
january14 is offline   Reply With Quote
Old 06-23-2015, 04:39 PM   #12
21 FBRS slide manual retraction
Hi,
I have a 2015 Forest River Micro Lite 21 FBRS and wish to know how to manually retract the slide. I don't believe I have the proper tool. And the owners manual pictures do NOT correspond with my unit. My slide is working, but had blown fuses and I'd like to be prepared!
BE
MediaProf is offline   Reply With Quote
Old 06-23-2015, 04:48 PM   #13
MediaProf
Manual location is under your couch & I believe it uses the same tool as for the stab. jacks.
Papa GLS is offline   Reply With Quote
Old 06-23-2015, 04:53 PM   #14
The tool is similar to the stabilizer jack tool. My wrench for the slide was black.
2013 Rockwood 2109S
2010 Dodge Ram 1500 Crew Cab 4x4 Hemi
GearHd6 is offline   Reply With Quote
Old 06-23-2015, 07:07 PM   #15
Manual Retraction of 21FBRS slide
Thanks,
Maybe I'm making this more difficult than it is, but I see nothing that would fit my Stabilizer Crank. Attached is a pic of what I believe to be the connection I have to mount to retract the slide...if so, I don't have the tool. If not, perhaps I'm just not seeing the connection.
Thanks,
MP
Old 06-23-2015, 07:35 PM   #16
It's not the same tool as the stabilizer tool, I just looks similar. The proper tool has a socket type end with a slot cut through it to engage that pin.
2013 Rockwood 2109S
slide
