Old 12-28-2018, 06:23 PM   #1
kbirkenfeld's Avatar
25BDRS Breaker
Quick question. What breaker is the receptacles tied too? Iím assuming itís the 15 AMP fridge breaker because it keeps tripping. We are trying use a oil radiator to assist in heating for our little family getaway to Branson.
kbirkenfeld is offline   Reply With Quote
Old 12-29-2018, 03:00 PM   #2
D W
D W's Avatar
No way of us telling with any certainty. You'll have to look at the breaker legend on the left side of the service panel. It's entirely possible that all of your receptacles are tied together. In that case 15 amps is all that circuit will handle.
'04 K3500 Silverado LS with LS3 Connect & Cruise- with Intimidator SSI PKG- Reprogrammed 4L80E
2016 Salem 27RKSS
D W is offline   Reply With Quote
Old 12-30-2018, 09:56 AM   #3
do it the other way around. get a 120 volt circuit tester ($5 at any hardware store). plug into shore power. turn one breaker off and then test each receptacle with the circuit tester to see if that receptacle has power. if not, it is protected by the breaker that is turned off. then to confirm, turn the breaker back on and test again with the circuit tester. it should now show power to the receptacle. take some time and trace down each and every receptacle. and write it down!
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is online now   Reply With Quote
Old 12-30-2018, 11:24 AM   #4
D W
D W's Avatar
X2! One of these should be in every RV'er's tool box. Available at Lowe's or HD.
Name:	GB GFI-501A.jpg
2016 Salem 27RKSS
Old 12-30-2018, 11:34 AM   #5
If you're running your water heater on electric, it's possible it's on the same circuit as the outlets. If so, the breaker isn't big enough to run both the water heater and the oil heater. Run the water heater on gas until you can separate the circuits.
Some people run their space heaters on a separate extension cord that they run through their slide and plug into the 15 amp outlet on the power pole.
2011 Traverse LT, 3.6L, FWD
breaker
