Old 08-12-2014, 10:12 AM   #1
26FKSS - Slide out not working - fuse location?
I closed up my 26FKSS on Sunday and noticed I forgot to put the antenna down. I went to open the Slide out room to get to it but it didn't respond. Based on what I've seen on this forum so far, it's most likely a fuse issue.
Is the fuse inline underneath the trailer, or is it among the fuse panel? My panel is labeled, but none of them say slideout. There are a couple handwritten labels that I can't read.
Are all 12 volt fuses the same (aside from the Amps)? I know I can get multi-packs at the auto parts store, but it seems like there are different sizes and I don't want to go back down to the site with a package of the wrong thing.
If it's not the fuse, I'm reading about being able to manually retract the room using a drill on the hydraulic gear. Any insight on how that works would help too. I'm not at the site with my trailer, so I'll have to go back down Saturday prepared to get this resolved. The manual can be pretty vague - especially with the fuse panel.
Steven and Ginger
2011 Flagstaff 26FKSS
2013 Dodge Ram 1500 Big Horn w/Hemi
SandGMoon is offline   Reply With Quote
Old 08-13-2014, 12:13 AM   #2
Ret E-9 Anchor-clanker
donanddona's Avatar
Ned to call the dealer. Good service departments can walk you thru issues..
donanddona is offline   Reply With Quote
Old 08-13-2014, 05:40 AM   #3
Slympicins's Avatar
Look under the front left and you will find a set of fuses. Find the right one and you set.
Chuck and Joanne
2014 Flagstaff Super Lite Classic 27RLWS Emerald
2013 Dodge 2500 4x4 Laramie Crew
Equal-i-zer 1200/12,000 4-point WDH
Slympicins is offline   Reply With Quote
Old 08-17-2014, 09:50 AM   #4
There is an LED next to each fuse. If the fuse is blown the light next to it will be on.
bradw661 is offline   Reply With Quote
Old 08-17-2014, 09:03 PM   #5
My fuse has needed to be replaced these last 2 trips and I am not sure why? Brand new 25ds microlite. First 2 trips no issues.
PTLady is offline   Reply With Quote
cat, fuse, location, slide, slide out
