Same Trailer - Flagstaff 26 FKWS
I have the same Trailer - 2015 Flagstaff 26 FKWS with the front dump valve under the slide out. Not that I like to do it but I connect the grey water hook up before putting out the slide and likewise disconnect after the slide is put in. When you are camped for a period of time and need to open the valve occasional, I put down a plastic tarp or piece of cardboard, get out my rubber kneeling pad and crawl under there. Its not great but possible to do. This is the least of the problems I have had with this trailer. The main slide takes up almost the whole opening between the from cupboards and the entertainment centre so I have to watch carefully when sending out or pulling in the main slide as it can catch on the cupboard knobs if the slide doesn't come in straight. I will PM you.
rthomaslyons
2019 Sunseeker 3010 DSF
