Old 04-13-2014, 02:32 PM   #131
Slympicins's Avatar
Where can you find them at? It would be worth it to have around especially if your out of state.
Chuck and Joanne
2014 Flagstaff Super Lite Classic 27RLWS Emerald
2013 Dodge 2500 4x4 Laramie Crew
Equal-i-zer 1200/12,000 4-point WDH
Slympicins is offline   Reply With Quote
Old 04-13-2014, 02:33 PM   #132
Slympicins's Avatar
Cat can you send a pic of it? Camper is down in storage till next weekend.
Chuck and Joanne
Old 04-13-2014, 02:49 PM   #133
cat1956's Avatar
Lippert Triple Flex Guard Kit
Tommy and Wanda
2014 Flagstaff 27RLWS
2014 F-150 4x4 Super Crew 3.5L Ecoboost Max Towing
Intergraded Brake Controller
Equal-i-zer 1,200/12,000 Weight Distribution w/ 4-Point Sway Control
cat1956 is offline   Reply With Quote
Old 04-13-2014, 03:12 PM   #134
Platokidd's Avatar
Location: Home of the 2016 WORLD SERIES CHAMPIONS CHICAGO CUBS
split loom
Originally Posted by chicagoslick View Post
I too have used split loom on all my exposed wiring. I was not impressed with how some of it was ran. I guess I'm just an anal person...BTW there is also an exposed wire on the left side of the couch I added split loom to, besides the wires that go down from the television...
I went split loom happy today. Did my brake wires ,they were just hanging and making contact with the leafs. Also did the power tongue jack, plug line tt to tv , awning wires, stab jacks, just had wires running into the frame.
Have more to do but I ran out of split loom.
2014 LaCrosse 323RST-TE-C
2009 CHEVY 2500HD Silverado Z71
2016- 92 nights of camping
Old 04-13-2014, 08:23 PM   #135
chicagoslick
chicagoslick's Avatar
Nice job!!!
Gary, Tonia, Baile, Summer and Otis our Boston T.
Flagstaff 27RLWS Emerald Pkg
2015 Ford F150 King Ranch FX4 Max Tow 3.5EB, 3.55
Equalizer 4 WDH, 1,200 / 12,000Lbs
chicagoslick is offline   Reply With Quote
Old 04-13-2014, 08:47 PM   #136
Slympicins's Avatar
Great. I never thought to look at the brake wires. Thanks for the heads up on that. Guess I will get busy while camping next weekend. Helps the day go by and I will feel like I accomplished another Forest River task.
Chuck and Joanne
Old 04-13-2014, 08:49 PM   #137
Slympicins's Avatar
Thanks Cat. I will be ordering a set here shortly. Just in case. Never know...I may need them or another fellow camper may need them to get home.
Chuck and Joanne
Old 04-15-2014, 07:51 PM   #138
Slympicins's Avatar
Good grief. Had to winterize the TT today. Snowed this afternoon and down to the 20's tomorrow. Ahhhhhh. What happened to spring and 80 degrees over the weekend?
Chuck and Joanne
Old 04-19-2014, 11:09 AM   #139
Slympicins's Avatar
27RLWS
For those with the 27RLWS here is a real good reason to TURN OFF THE WATER when you leave.
I closed the compartment where the water heater and water filter is located. I walked over to my neighbors camper for less than 1 (one) minute to talk. My buddies wife came out of the camper next to ours and yelled, Guys we have a problem here!" The water filter housing backed it's way out and was dumping water inside the compartment. Got a little inside on the carpet to. The filter housing DOES NOT LOCK into place and slowly backed out. As a result, I deleted (removed) the entire water filter system and added a section of pipe where the top if the filter was. I didn't trust it not to do it again. It cost about $15.00 for the pipe and fittings but no more worries!!!!
Chuck and Joanne
Old 04-19-2014, 11:09 PM   #140
Yea, I wasn't happy to see a filter coming on ours. I've never had one but have camped with friends that did. Everybody struggles with them either with leaks or low pressure. On my short list to permanently remove it.
cub22908 is offline   Reply With Quote
