Old 05-06-2014, 09:15 AM   #171
Originally Posted by OldCoot View Post
Shocks on the trailer mitigates a lot of these problems.
If 10K is a typical price then I can't afford this retrofit kit
Had a closer look - all products discontinued but looking at the few brackets in each kit the price should be $10. Maybe $10K is why they were discontinued!
I notice another thread on this issue (adding shocks to TorFlex axles) - did you ever get them installed?
Regards,
Wayne
2014 Flagstaff Super Lite 27RLWS Emerald Edition | Equal-i-zer 1200/12,000 4-point WDH
2010 GMC Sierra SLE 5.3L | K&N filter | Hypertech Max Energy tune | Prodigy P3
Wmoses is offline   Reply With Quote
Old 05-10-2014, 11:02 PM   #172
Devilscreekw's Avatar
Hey y'all
Just picked up my 2015 (yes I typed 2015) 27RLWS in Des Moines on Thurs afternoon and got it back to Canada by Friday evening.
After having read through the entire thread the last few weeks, I was surprised to discover the sofa problem has been solved by.......Not Fastening It Down at ALL... Yep, mine is just sitting there like a loose piece of furniture. Fortunately, it caused no damage in my 13 hr drive home. I think maybe I'll just cut a piece of wood to space it out from the wall. It doesn't seem to have any tendency to migrate out to the centre.
I did have one problem, though. The 8' long piece of aluminum skirting from the front right corner to the steps cracked off on the highway after we'd been on the road about an hour. It appears one of the support brackets failed, and the skirting vibrated away till it tore off. Again no damage to the rest of the unit, and I should be able to fix it easily once FR sends up the piece.
I did have trouble with the steps opening up on the highway. They folded completely out twice before I zip-locked both sides till I got home. Any body else have this problem, and what did you use to secure them during travel?
Harv & Deb
2015 Flagstaff 27RLWS
2010 Ram 2500 4x4 crew 5.7 Hemi, 3.73
Equalizer 1200 4 pt. Tekonsha controller
Devilscreekw is offline   Reply With Quote
Old 05-11-2014, 10:53 AM   #173
dannyabear's Avatar
You have to push the steps in real hard for them to lock in place; If you are too gentle with them they will open
Danny & Darlene
2002 Silverado 1500HD
2014 Rockwood 2703WS 'Emerald Pkg'
Days camped 2015=42 2014=48 2013=41 2012=47 2011=18
dannyabear is offline   Reply With Quote
Old 05-11-2014, 11:09 AM   #174
Originally Posted by Devilscreekw View Post
... I did have trouble with the steps opening up on the highway. They folded completely out twice before I zip-locked both sides till I got home. Any body else have this problem, and what did you use to secure them during travel?
I have never had this problem and would love to know what happened in your case.
The steps have 2 folds-in and then a slide in operation to stow. The slide in must go all the way in so that the assembly drops down maybe 1/2" into a slot at the end of the "track" in the side plates. It is this dropping down that secures the steps in the stowed position, since to deploy the steps one has to lift and pull out the whole assembly and then do the two fold-outs. Wish I had a pciture to show what I mean. So for it to deploy when underway would mean a simultaneous turn to the left at the same time hitting a bump so that the assembly jumps up and out of the slot - very hard to do.
Sorry to hear of the skirting. Mine is in good shape after over 2000 miles of travel and a "coming together" of the sofa slide skirt with a small plastic coated concrete post next to the electric post at a recent campsite. Just pulled the skirt back out and used a rubber mallet to knock out the dent in the skirt. Looks good and the brackets held throughout.
Regards,
Wayne
Old 05-11-2014, 11:13 AM   #175
Yeah, the top step locks in (but still bounced out), but the bottom two steps don't appear to lock, and they just rolled over and came down.
Harv & Deb
Old 05-11-2014, 11:14 AM   #176
tomjsas's Avatar
On my 2010 2501ss TT we had that problem once on a trip to Glendo Wyoming. However, during that trip it was raining and blowing directly across the highway from the drivers side. Steps blew out twice. Ended up using a bungee cord the rest of the time. Have not had issue with the 5er steps although the are the same design.
Tom - 2014 8289ws, 2011 Chevy 2500HD
Tom
Pull-Rite 16K Super 5th
2014 Rockwood Signature Ultra-Lite 8289WS
2011 Chevy 2500HD - DuraMax (Just over 5000 miles now!)
Nights camped in 2014 - 21
tomjsas is offline   Reply With Quote
Old 05-11-2014, 11:41 AM   #177
Okay thanks for clarifying. I thought there was complete deployment. There is no locking of the folding bottom steps so they could flip out as in your case but I would think that would take some significant input force to do that. Not having that experience I must defer to those who have.
Regards,
Wayne
Old 05-11-2014, 01:29 PM   #178
Makes sense now. We had a 35mph wind from the driver's side as well. I was using my old hitch from my Layton 220, a 750 lb Draw-tite WDH with no anti sway, and rush hour out of Des Moines in those hills with bumper to bumper semis was not something I want to repeat soon. It took till Watertown SD where I 29 flattens out and traffic tapered off that I could relax a bit, but still had an unbelievable wind till well into the evening. Kept my cruise around 92 Km (56mph) till then. My Equalizer 4 pt. did not arrive in time for my trailer arrival.
Harv & Deb
Old 05-18-2014, 09:29 PM   #179
New washer-dryer for those long road trips
Check out this review of my latest acquisition for the RV. I expect to put it at the end of the counter, just under the counter extension. When travelling I believe it will fit between the sofa and the dinette.
Now I am all set for my next road trip!
Regards,
Wayne
Old 05-19-2014, 05:46 AM   #180
cecelea's Avatar
Hey y'all
We had the same problem with our skirting. Called FR and they replaced the entire skirting because ours started to rip off.
Our couch is not fastened down and does not move even on rough terrain!
Enjoy your new home away from home!
cecelea is online now   Reply With Quote
