Old 06-07-2014, 10:10 AM   #241
Have any of you mounted the 5 inch fence posts under your 27RLWS? l would like to know what length you cut them to that works out good. My trailer is in storage and I would like to have them all ready to install when I get it out at the end of the month. I have fabricated clamps to fit the frame so they will be under trailer just a little behind the left storage door. All I need to know is a good length for the posts . Thanks.
cub22908 is offline   Reply With Quote
Old 06-07-2014, 02:48 PM   #242
Slympicins's Avatar
Ah? 5" fence posts? What would they be for?
Chuck and Joanne
2014 Flagstaff Super Lite Classic 27RLWS Emerald
2013 Dodge 2500 4x4 Laramie Crew
Equal-i-zer 1200/12,000 4-point WDH
Slympicins is offline   Reply With Quote
Old 06-07-2014, 02:54 PM   #243
cecelea's Avatar
Not sure I understand what you are talking about.
cecelea is offline   Reply With Quote
Old 06-07-2014, 03:14 PM   #244
It is a very popular mod in the modifications thread. Thought most people knew about it, sorry. It's mounting 5 inch square PVC fence posts under RV for sewer hose and folding RV ladder storage. The posts are 8 feet long and the trailer is 8 feet wide so there should probably be some cut off to make it less visible. I posted here as I have a 27RLWS but if nobody has made this mod on this trailer I'll go over to the mod thread. Thanks.
Old 06-07-2014, 04:32 PM   #245
Slympicins's Avatar
Sounds great. Send some pics.
Chuck and Joanne
Old 06-09-2014, 04:00 PM   #246
Slympicins's Avatar
27RLWS
Okay Wayne here it is. Picked up the TT today and brought it home. No problem with the brakes it's the WDH which I greased. I did check my wheel well clearance on a nice flat road (in front of the house which is not a traffic issue). I have 3" of clearance from the top of the tire to the top of the fender well on the right side (dinette side). I measured the left side (kitchen slide) and discovered it was only 1 3/4 to 2". Spoke to the big guy at the CG where I store the TT and he said that could be an issue. I looked at the axle stickers and found they are both 3,500 lbs rated axles (hum). The dry weight of the 27RLWS is 6,353 and a never exceed cargo weight of 1,153. That's a 7,506 total weight give or take a few. The two axles at 3,500 is 7,000 lbs which leaves 506 pounds overweight. Does that make sense to you? It's no wonder she leans to one side going down the road. I get it that the kitchen slide would be heavier (?) than the dinette slide as the wardrobe slide is on the same side. But...there is nothing I store on that side, nor have I exceeded 500 pounds of normal stuff in the TT. I have a call into the dealership since Dexter didn't even want to here about it and told me to call Forest River direct. I'm going to see what the dealer can do and go from there.
Chuck and Joanne
Old 06-09-2014, 05:11 PM   #247
Canadian Member
itat's Avatar
The designer would spec the axles assuming at least 10% of the weight will be on the tongue. You'd be wise to go to a CAT scale and weigh your trailer fully loaded to confirm the weights on each axle and the tongue.
Maybe someone else here can advise you on how to gets weights on each wheel to see if something is out of whack there.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer
2016 Ford F-250 XLT SuperCrew, 6.2L, 4x4, 6'9" bed, 3.73
Fondly remembered:
2009 Ford F-150 XLT SuperCrew, 5.4L, 4x4, 5'6" bed (2012 - 2016)
Old 06-09-2014, 05:16 PM   #248
Slympicins's Avatar
Here is the door sticker:
Name:	ImageUploadedByForest River Forums1402352169.923386.jpg
Chuck and Joanne
Old 06-09-2014, 05:19 PM   #249
Slympicins's Avatar
That would make sense giving 10% + to the tongue weight being around 750 lbs plus. Still the lack of clearance is yet a concern.
Chuck and Joanne
Old 06-09-2014, 05:47 PM   #250
Canadian Member
itat's Avatar
I agree that it's odd to have that much difference between the 2 sides. If you park the trailer on level ground side to side, do you still have the same difference in clearances?
If you've never taken the trailer to a scale it would be worth the peace of mind to confirm you're OK with your weights on the axles and that your weight is distributed well front to back.
Ask your dealer if they can weigh each wheel to see if you're a lot heavier on one side compared to the other which might cause the leaning if that's what's happening.
BTW, I watch this thread because I love the floor plan and would love to upgrade from my Roo to your floor plan some day.
Fondly remembered:
