Old 06-12-2014, 10:47 PM   #271
Originally Posted by dannyabear View Post
Got to be careful about the one over the sink when closing the slide with thr fridge and couch, I almost ripped it off too
Good tip Danny, although there is less chance of that happening (knock on wood) since the puttng away routine is much more involved and is done by my wife and she is pretty good about checking before pulling in the slides.
Regards,
Wayne
2014 Flagstaff Super Lite 27RLWS Emerald Edition | Equal-i-zer 1200/12,000 4-point WDH
2010 GMC Sierra SLE 5.3L | K&N filter | Hypertech Max Energy tune | Prodigy P3
Wmoses is offline   Reply With Quote
Old 06-12-2014, 10:48 PM   #272
Slympicins's Avatar
I guess I need to make a check list and follow it to the letter. My pilot days will help conjure a decent check list. I followed them to the letter and I can follow a TT checklist.
Chuck and Joanne
2014 Flagstaff Super Lite Classic 27RLWS Emerald
2013 Dodge 2500 4x4 Laramie Crew
Slympicins is offline   Reply With Quote
Old 06-12-2014, 10:52 PM   #273
Originally Posted by Slympicins View Post
My awning wall leaks in the same place. Was told there is a seam up there that may have to be sealed. Someone said it was pretty common. As they say "it happens". I can't get all upset about it but it does keep my mind off of everything.
That is actually good to hear and sort of what I expected. I don't believe that it flexes a lot so the fix should not be hard. Will probably seal the whole length of the awning seam and be done with it forever.
Regards,
Wayne
Old 06-12-2014, 10:54 PM   #274
dannyabear's Avatar
The aluminum gutter rail is spliced right before the speaker, I put a drop of silicon on it and quit leaking there
Danny & Darlene
2002 Silverado 1500HD
2014 Rockwood 2703WS 'Emerald Pkg'
Days camped 2015=42 2014=48 2013=41 2012=47 2011=18
dannyabear is offline   Reply With Quote
Old 06-12-2014, 10:56 PM   #275
Slympicins's Avatar
It's amazing how stuff we have to do. But...I still have a ton of fixes to do in the house. So, it's about the same I guess. Only difference is my house doesn't roll down the hill every now and then. Lol
Chuck and Joanne
Old 06-12-2014, 10:56 PM   #276
Canadian Member
itat's Avatar
I had the same kind of leak past the awning mounting rail on my Coleman pup. It probably just needs a bead of caulk along the top of that mounting rail. I found that with the pup I was stretching the awning too tight and when I loosened it off a bit the leak stopped. I don't know if that's possible with an electric awning.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
Old 06-13-2014, 05:42 AM   #277
Clean inside the Gutter at the connection,dont use caulking or silicone as this will (Build a Dam) in the area. Wrap a piece of (Eternabond) around a wood pencil and lay in the gutter,allowing (2in) beyond the seam on both sides. Measure how much it will take to go up both sides and across the bottom,and roll this up on the pencil! The (Eternabond) only gets applied to the (Inside) of the gutter! Youroo!!
Old 06-13-2014, 09:01 AM   #278
Sounds like a good tip. Thank you.
Regards,
Wayne
Old 06-15-2014, 07:53 PM   #279
Devilscreekw's Avatar
Speaking of Water!!!
Well we just completed our first long trip with the new trailer, but unfortunately the weather did not cooperate...meaning one super nice day and 4 days of driving rain....including the 2 eight hour pulls. And when I say rain, I'm talking Biblical.
After each pull, I found water on the floor in front of the range which is getting the carpet wet. If I lift the carpet up the upper side of the floor of the slide seems to be dry. I think its being thrown up into that corner by the leading tire on the drivers side, and seems to be migrating through and around the corner heading to the rear of the trailer. I haven't had a chance to pull the slide in, and look for a possible entrance.
Anybody else run into something like this?
Also, it was my first run with the Equalizer 4 pt. Best $500 I ever spent. Trailer felt totally different. I lubricated mine (it did come with grease on those surfaces from the factory) so I've been refreshing it before each pull. I really haven't noticed any noise at all. My old Draw-Tite made more noise at low speeds.
Harv & Deb
2015 Flagstaff 27RLWS
2010 Ram 2500 4x4 crew 5.7 Hemi, 3.73
Equalizer 1200 4 pt. Tekonsha controller
Devilscreekw is offline   Reply With Quote
Old 06-15-2014, 09:41 PM   #280
Slympicins's Avatar
Harv I hadn't noticed anything like that in mine but I can honestly say we haven't driven through biblical rain showers. We have had some while camping but have been lucky while traveling. Take pictures when you locate the issue.
Chuck and Joanne
