Old 08-23-2014, 01:47 PM   #431
One other plus that we found is that the 2 rear windows open!! The 2014's on the lot did not open at all. They don't open far, maybe 3", but it's airflow.
seashel29 is offline   Reply With Quote
Old 08-23-2014, 09:25 PM   #432
Canadian Member
itat's Avatar
Originally Posted by seashel29 View Post
No.......it unfolds and ends up that your feet would be on the seat cushions of the couch, and your torso is on a foam? cushion, and your head is on a smaller foam cushion that's revealed when unfolded. It works pretty easy, but it just totally unexpected. I guess we're not that disappointed since we've also heard of problems with the air mattress type.
That would be easier to set up than an air bed
Our DS has slept on the jack knife sofa for 2 seasons and never complained it was uncomfortable so yours should probably be equally fine.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer
2016 Ford F-250 XLT SuperCrew, 6.2L, 4x4, 6'9" bed, 3.73
Fondly remembered:
2009 Ford F-150 XLT SuperCrew, 5.4L, 4x4, 5'6" bed (2012 - 2016)
itat is online now   Reply With Quote
Old 08-23-2014, 10:17 PM   #433
We used our air mattress for the first time last weekend when my daughter and granddaughter spent time with us during our just-concluded road trip to see them in So.Cal.
The air mattress inflated and deflated with ease using the built-in pump and was easy to put away and set up. I cautioned the girls that there was to be no sharp objects on the bed and they said that it was nice and flat and even more comfortable than their beds at home.
I'd be interested to see a photo of this three-section fold-out bed of yours, seashel.
Regards,
Wayne
2014 Flagstaff Super Lite 27RLWS Emerald Edition | Equal-i-zer 1200/12,000 4-point WDH
2010 GMC Sierra SLE 5.3L | K&N filter | Hypertech Max Energy tune | Prodigy P3
Wmoses is offline   Reply With Quote
Old 08-30-2014, 10:51 AM   #434
One thing we've found not working in the new TT is the charging station outlet. It has 2 USB ports and a 'car charger' outlet. Any ideas of something simple to check before it becomes a dealer problem? The radio and outlets near the charging outlets all work. It's just the USB that's not working.
Old 08-30-2014, 03:19 PM   #435
I would unscrew the faceplate and pull it out, exposing the wires, then I'd use a multi-tester to check for current at the USB ports if there were no obvious disconnected wires, etc.
Now I have not done this myself because I have never used the USB ports so I don't know what is behind the faceplate.
Regards,
Wayne
Old 08-30-2014, 03:52 PM   #436
Equalizer Weight distribution, sway control
2008 Cardinal 30RK fiver.
2009 Chevrolet 2500HD DuroMax
2009- 42 days; 2010-40 days, 2011- 40 days. 2012- 30 days,
2013- 14 days, 2014- 21 days, 2015- 42 days
Wanderer is offline   Reply With Quote
Old 08-30-2014, 08:57 PM   #437
Canadian Member
itat's Avatar
Seashel29, I found this video of a KZ Spree model TT that probably has the same unfolding sofa as in your new Flagstaff. All RV manufacturers use the same component manufacturers so FR is likely using the same sofa manufacturer as KZ. Is it the same as yours?
Fondly remembered:
Old 08-30-2014, 09:48 PM   #438
Old 08-30-2014, 10:28 PM   #439
I disagree with the guy in the video who says it's the nicest sofa in the RV industry. That sofa has 3 segments at 3 different heights. I wouldn't want to sleep on that. I would much prefer the air mattress that mine has. Even surface and good support. And the inflating and deflating is not an issue except when salesmen are trying to pitch the RV they are looking to sell.
Regards,
Wayne
Old 09-01-2014, 06:49 PM   #440
I choose to go with the husky equalizer hitch has built in shocks to eliminate sway
19redwing is offline   Reply With Quote
