Old 03-12-2015, 07:27 AM   #611
Brazealnut4's Avatar
Are those fuses a different type than those in the fuse panel?
Mike
2015 Flagstaff 27RLWS Emerald Package
2013 Ford F150 STX 5.0 V8 3.55
Brazealnut4 is offline   Reply With Quote
Old 03-12-2015, 07:33 AM   #612
Canadiancrew's Avatar
Yea our new trailer will be coming soon so I also would like to know what type of fuses these are so I can stock up before our first trip.
Orval and Yvonne
2016 Flagstaff 27RLWS Emerald Package
2011 F150 SCrew XTR 5.0L 4x4
Canadiancrew is offline   Reply With Quote
Old 03-12-2015, 08:15 AM   #613
When I picked up our new trailer I asked the service tech about spare fuses during the PDI and he threw in about a dozen spares. Always pays to ask.
2015 Rockwood 2703ws
2013 Ford F-150 5.0 3.55
Rockwoodjoe is offline   Reply With Quote
Old 03-12-2015, 04:56 PM   #614
Slympicins's Avatar
Oh it does. They are not cheap. You can buy them at any auto parts store, Lowes and Home Depot. Definitely ask for back up fuses and if they toss them in, great. Ask for roof vent covers and the bug screens for the water heater and heater. My dealer through them in because I bitched at them about failing to properly prepare for our walk through. It's costs them close to nothing so ask or better yet, demand they put them on.
Chuck and Joanne
2014 Flagstaff Super Lite Classic 27RLWS Emerald
2013 Dodge 2500 4x4 Laramie Crew
Equal-i-zer 1200/12,000 4-point WDH
Slympicins is offline   Reply With Quote
Old 03-15-2015, 11:25 AM   #615
Well we are 5 days into our FIRST trip.
Been to TN and SC. LOTS of rain.
Just noticed today that the narrow closet to the right of bed was slightly damp inside. Not the Carpet . Just the side. UH OH! Also noticed the cabinets above the bed slightly damp.
Looks like it will be going to the shop when we get back.
Has anyone else had this issue?
Also noticed the sofa only had 1 of 4 bolts tightened (common problem reading through this thread)
And the cabinet above tv keeps opening up while traveling.
2015 Flagstaff 27RLWS http://www.registerrvs.com/vehicleim...4919%20|404827
Pulled w 2006 Dodge Ram 3500 Laramie Crew
Upgraded from 2008 Wildcat 5th wheel
Lori_Allen is offline   Reply With Quote
Old 03-15-2015, 04:53 PM   #616
BIL thinks moisture was just condensation. I hope so!
Old 03-15-2015, 05:25 PM   #617
Does anyone full time with this unit. I know a class A would probably be the better route, but not ready to drop the $100k.
2015 Rockwood 2703ws (27rlws clone)
2013 Ford f-150 5.0 3.55
Old 03-17-2015, 08:51 PM   #618
Slympicins's Avatar
When the wardrobe slide is closed, get up on the bed and look all around the seals on top of the slide for sunlight (this done preferably in a bright sunny day). Areas where you can see daylight through the seals are the issue. Do the same with the dinette and kitchen slide. Check your water filter.
Chuck and Joanne
Old 03-20-2015, 07:45 AM   #619
beechjet16mf's Avatar
We just finished our second big trip in our Flagstaff 27RLWS. We started last fall, were gone for five months, and traveled thru 13 states, ending up in Arizona. Total miles were 8330 and our Suburban averaged 10.8 MPG . The only problem was the black water handle was broken by a rock, luckily, it was empty, and there was an RV parts place in Wickenburg, AZ. We are still running on the original Westlake tires. I have a TPMS, and check inflation and run the tires 5 psi above the normal pressure. We have almost 18,00 miles on the tires and they still are looking good, wear wise.
Will probably change them before the next big trip.
beechjet16mf is offline   Reply With Quote
Old 03-20-2015, 07:54 AM   #620
We had a lot of rain in Phoenix for a week, and found that we had condensation issues in the wardrobe slide. We had to crack the bathroom fan to let the moisture out. We actually had drops of water running down the outside wall of the closet. We hadn't had a door or windows open for a while.
