Old 07-19-2016, 05:30 PM   #741
Canadiancrew's Avatar
Ok somewhere in this string that is too long long to read anymore is a post about skirting coming off. So we are ready to depart on a long cross 6 states and 3 provinces trip and I notice the caulking on the strip of skirting in front of the door is all coming off. Obviously it's flexing while driving. Glad I saw it before we set out. The screws holding the skirting too the wall where 5 feet aperture. The aluminum brackets underneath where 6 feet apart. So I added 2 more brackets and more screws. Will need to touch up the caulking later but at least I won't be loosing or damaging the skirting.
Orval and Yvonne
2016 Flagstaff 27RLWS Emerald Package
2011 F150 SCrew XTR 5.0L 4x4
Canadiancrew is offline   Reply With Quote
Old 07-20-2016, 04:13 PM   #742
Devilscreekw's Avatar
That was me.....in the first hour of ownership. That is the same section that I lost. You are headed down the right road. Additional brackets solved the problem.
Harv & Deb
2015 Flagstaff 27RLWS
2010 Ram 2500 4x4 crew 5.7 Hemi, 3.73
Equalizer 1200 4 pt. Tekonsha controller
Devilscreekw is offline   Reply With Quote
Old 07-20-2016, 04:50 PM   #743
Saw a Flagstaff that had survived a NY to CA to NY in 2008 with the skirting cracked along the slideout. When I got home I made a reinforcement with a flange welded to it and installed on the front and rear of the slideout of our new 2008 Flagstaff. When we traded it in for the 2012 5er, I removed the reinforcements and re-installed on our 5er. Our oldest son tig welded the reinforcements.
Name:	Slideout Trim Reinforcement Frt.JPG
ID:	114771   Click image for larger version
Name:	Slideout Trim Reinforcement Rear.JPG
Old 07-20-2016, 06:40 PM   #744
Well thanks, even though I could not find the post the memory of it came in very helpful.
Any idea what type of caulking to use. I amd running out of time before the trip and can patch that up later.
Orval and Yvonne
Old 07-20-2016, 06:41 PM   #745
That looks like a great mod to eliminate the flex in the skirting. I will have to find someone that can tig weld.
Orval and Yvonne
Old 07-21-2016, 05:30 AM   #746
B and B's Avatar
Agreed this is a good mod. The old Chevy must have served you well running over the Mountains too!
B and B is online now   Reply With Quote
Old 07-21-2016, 10:26 AM   #747
I just went to Home Depot and bought a tube of brown silicone for eavestroughs. Color was real close to original, and has been on for 2 years with no issues.
Harv & Deb
Old 07-24-2016, 05:06 AM   #748
Pinn's Avatar
I may be paranoid about this but after losing my last trailer, I would rather be safe than sorry. The door in between the bedroom and the hallway looks to be separating from the wall. Is this a common happening ? Can I fix myself and be done with it or should I take it in to be looked at someone else?
ID:	115055   Click image for larger version
2013 Flagstaff 27RLWS - Chole'
NC
Pinn is offline   Reply With Quote
Old 08-15-2016, 09:38 AM   #749
Flexco Step problem
We had one of the aluminum rivets shear in the first couple of months of ownership. I replaced it with a bolt, and there were no further issues. Then this past weekend this happened.
Now I have to admit that this was a result was a result of a very large person (my wife's oldest son, 6'3 and 350 lbs.) using the unit.
I guess my concern is how I am going to brace this part so it doesn't happen again? My wife invites her son's family to camp with us EVERY time we go out. For three years now.
Harv & Deb
Old 08-15-2016, 10:07 AM   #750
Find a pc of solid rod that will fit in the tube and then re-weld the tube. Make sure the solid rod goes thru the entire length of the tube. Also replace ALL the rivets with gr 8 bolts and nyloc nuts.
