03-03-2016, 10:17 PM
27RLWS Bedroom TV
I have a 2015 27RLWS. The Bedroom TV was mounted covering the top half of the electrical outlet. Can I move the TV bracket up so I can have access to both plug ins?
03-04-2016, 12:19 AM
I have the same unit but it did not come with a 2nd tv. The wall has a label as where to mount it. I would assume you couldn't move the mount based on the label.
Mike
2015 Flagstaff 27RLWS Emerald Package
2013 Ford F150 STX 5.0 V8 3.55
03-14-2016, 01:02 PM
LarryM158
Picking up our 2016 27rlws soon and have a question. The 2015 has the same trailer front as the 2016. Due to the uneven surface on the lower half of the front my dealer is telling me that they cannot install a diamond plate rock guard. What if any solution or suggestion do you have on this issue.
Also I am using an IPAD to access the FROG site & need to know how to post a question on this site. Any help would be greatly appreciated. I accessed the site using my ID & people, but have done nothing more other than replying to your post?
LarryM
03-14-2016, 01:20 PM
From what I was told from FR when ordering our Rockwood 2703 the Flagstaff's Sister was some late 2015's had the older front cap with the diamond plate then in early 2016 that switched over the newer one piece cap.
I have heard some people have tried using the PlastiDip Spray (Rubber Texture) on the front cap to protect it from rocks, Chips...etc if you don't like the results it can be easily removed. It's comes in different colors including clear.
2015 Ram 2500 CTD,CC,SB,4x4
2016 Rockwood 2703 Emerald Edition
Husky CenterLine TS Hitch
TST 507 TPMS
Progressive Industries EMS-PT30X
03-14-2016, 02:37 PM
LarryM158
EJS4029,
Thank you for your reply.
LarryM158
04-15-2016, 03:24 PM
LarryM158
Just. Picked up our 27rlws this past Tuesday 4/12 and we had the 19 inch Tele mounted above the electrical wall outlets. Will provide picture if needed.
Lorocon158
04-15-2016, 08:01 PM
I was pretty sure that this TV was just mounted to low.
04-15-2016, 08:13 PM
LarryM
On the home page, click on one of the appropriate forums. Then, on the upper left you will see New Thread. Click on that and you will be able to start posting your question. Be sure to give it a title.
_____________________________________________
2010 Ford F-150 Crew Cab
2015 Salem Hemisphere 263RL
01-27-2017, 11:56 AM
Lorocon158
I know your post is nearly a year old, but I am thinking about adding a 19" television to our bedroom. Is the offer to send pics still available?
Thanks.
01-27-2017, 12:12 PM
It depends on how high the support is behind the wall. Bump on the wall with your fist and see it it fills solid or not. I could tell a difference on my 2014 27RLWS.
Tommy and Wanda
2014 Flagstaff 27RLWS
2020 Ford F-150
Equal-i-zer 1,200/12,000 Weight Distribution w/ 4-Point Sway Control
01-27-2017, 12:49 PM
Thanks for your response. I do have a support for the television behind the wall, but I'm really wondering how the clearance is (pics needed) with mounting a television between the two doors, and, how difficult does it become maneuvering around a already tight area.
01-27-2017, 02:02 PM
LarryM158
I have a 2016 27rlws TT with a 19inch tv on the wall. I had the bracket installed at the dealer prior to delivery. We have no problems getting by between the TV and the bed, going out bedroom door, or into the bathroom from the bedroom.
Larry Murphy Old Forge NY
01-27-2017, 02:16 PM
Go to know! Thank you for your prompt response.
01-28-2017, 06:29 PM
Bought a 19" Insignia LED television and a Rocketfish full motion wall mount from Best Buy for the bedroom (27RLWS). You are right, perfect spot and no hassle as far as space goes. Need to buy a couple of 1-1/2" lag screws for mounting the bracket though. I'll post pics to you here in a few days.
Thanks again for your input.
01-30-2017, 07:40 PM
LarryM158
Look forward to seeing the Pic's. My TT is in storage waiting patiently for the Spring.
Lorocon158
