Old 09-27-2014, 11:32 PM   #21
Randy and Diane's Avatar
Update to Update: We solved the problem with our slideout not retracting properly.
The trailer is fine -- the problem was mine. Because we do not tow the trailer I attempted to stabilize our "Cottage" last June by building 2 wooden pedestals and
placed them under the tail end of the frame where scissor jacks could be attached. It turns out that I made them a touch too high with the 12" lengths of 2" x 4" wood. Apparently, the rear corner on the door side was just that bit {2 1/2"} high so that when I retracted the dining slide it shifted forward and would not track properly. Today when I removed the pedestals the slide realigned itself. When I extended the slide and then retracted everything moved smoothly and sealed tight all around the perimeter. In summary after our first summer in the 27RLWS the only factory fault was the kitchen drawers were not secured and tilted when opened. It was an easy fix to add a small piece of wood under the thin shelf for the drawer frame screw to bite into and not pull out. We are also very happy with the after sale service and attention we have received from Prairie Sky RV in Coaldale, Alberta. Chase and his crew helped me with advise and recommendations several times. When I presented the slide problem to him initially he was accomodating and considerate even though their shop was very busy. We had what I consider to be the best of customer service in all aspects of our new Flagstaff 27RLWS adventure. Thanks to all who commented and offered advise. Have a safe winter and ask Santa to give us an early/long summer next year.
2014 Flagstaff 27RLWS
Planned 10 year cottage (no Truck)
Prairie Sky Rv, Coaldale, Alberta
Randy and Diane is offline   Reply With Quote
Old 09-28-2014, 04:35 PM   #22
Slympicins's Avatar
That's great to hear. Our drawers came apart during the walk through. Seems they placed the screw through the thick wood into the thin wood. I just reversed the screw so it bites into the thicker wood.
Chuck and Joanne
2014 Flagstaff Super Lite Classic 27RLWS Emerald
2013 Dodge 2500 4x4 Laramie Crew
Equal-i-zer 1200/12,000 4-point WDH
Slympicins is offline   Reply With Quote
Old 10-21-2014, 11:15 PM   #23
Yikes! Just bought 2015 keep us posted! Good luck!
antandjoettrv is offline   Reply With Quote
Old 10-22-2014, 07:36 AM   #24
No need to get alarmed. Not all trailers are the same, and the problems that one has might not show up in yours. For instance, in my case the only problems I had with mine were the radio (up an quit one fine day with no explanation - replaced under warranty) and the oven (never worked right - replaced along with the stove top, under warranty after a lot of trial and error waste of time).
Enjoy the trailer and be prepared to baby it and perform some work yourself even if it appears to be a warranty item (if you are handy that is) since the dealers either are too busy and will waste too much camping time, or they are lacking in competence to do the job right the first time. RV quality standards are pretty low - construction or dealer representation.
Regards,
Wayne
2014 Flagstaff Super Lite 27RLWS Emerald Edition | Equal-i-zer 1200/12,000 4-point WDH
2010 GMC Sierra SLE 5.3L | K&N filter | Hypertech Max Energy tune | Prodigy P3
Wmoses is offline   Reply With Quote
Old 10-22-2014, 09:06 AM   #25
No need to keep you Posted,the O/Post was about their (Slideout Tipping)! The O/Poster has now admitted/updated that the (Slidout Issue) was self inflicted and (All is Well with the Slideout)! Youroo!!
Old 10-22-2014, 08:02 PM   #26
slide
