Old 09-21-2014, 05:19 PM   #1
Randy and Diane's Avatar
27RLWS dining slide tips when retracting
We have just winterized our 2014 Flagstaff 27RLWS for the first time. Everything went as planned until we retracted our dining room slide. Since we never move our "Cottage" this is the first time we have retracted the slides. The kitchen slide and the wardrobe slide came in fine. The Dining table slide is a different type and when it moved it tilted up severely. I stopped it midway and extended it back out then tried retracting again. I did this several times and each time the slide tipped upwards then dropped down then back up then back down (on one occassion it almost hit the ceiling). The slide would retract completely each time but the front side edge does not compress the horizontal rubber seal at the top. The rear side edge does compress the rubber. The front side edge is very tight to the trailer opening while the rear side edge has a big enough gap for the vertical seal flap to lay flat. I am thinking the slide is off center and needs to be realigned. I am concerned that it tips up and falls so severely. Has anyone else experienced the same condition when retracting. I am going to the dealer next week but would like to hear from other rver's if possible. This is a great forum and we have received much valued information over the summer. Thanks for any comments.
Planned 10 year cottage (no Truck)
Prairie Sky Rv, Coaldale, Alberta
Randy and Diane is offline   Reply With Quote
Old 09-21-2014, 05:48 PM   #2
Slympicins's Avatar
Our dinette slide will raise up (the outer wall) and then slide out. Just as its at its full extension the outside wall of the slide will rise up and seal in place. I can say (luckly) I have not experienced the situation you described with the inside of the slide rising up. Did you check under the slide to see if you could see something buckling as someone hit the slide in switch? It could be out of adjustment. WMoses is a great source for answers. He will chime in soon.
Chuck and Joanne
2014 Flagstaff Super Lite Classic 27RLWS Emerald
2013 Dodge 2500 4x4 Laramie Crew
Equal-i-zer 1200/12,000 4-point WDH
Slympicins is offline   Reply With Quote
Old 09-21-2014, 05:59 PM   #3
mark0224's Avatar
Mine tips up a bit when you start to bring it in but nothing like your describing but once started stays even until it's all the way in then it tips down again.
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 09-21-2014, 10:36 PM   #4
The operation of mine is as described by Chuck and Mark - just a slight angular motion in the vertical plane as the seal is made with the wall of the RV when either extending or retracting.
It would appear that your slideout is significantly out of alignment in two directions. Since it may still be under warranty you may want to consider taking it to the dealer ASAP top get that straightened out. I have no other insight on this, I am afraid.
Regards,
Wayne
2014 Flagstaff Super Lite 27RLWS Emerald Edition | Equal-i-zer 1200/12,000 4-point WDH
2010 GMC Sierra SLE 5.3L | K&N filter | Hypertech Max Energy tune | Prodigy P3
Wmoses is offline   Reply With Quote
Old 09-22-2014, 11:33 AM   #5
Just an update to our slide problem. Firstly, again thankyou for your feedback on this Forum. I had emailed our dealer Prairie Sky on Sunday and the service manager called me back first thing Monday. He says this has happened before and perhaps the drive mechanism has jumped a gear. They are understandably busy this time of year winterizing rvs but will try to check out the slide on site and bring it in to their shop to fix over the winter if necessary. This is the only serious issue we have had with our 27RLWS since starting to use it last May. We use it as a stationary cottage and have been very pleased with the quality of build, floorplan, and emerald package styling. Visitors have really liked the layout and are amazed with the roominess and counterspace. Things like this happen but it is nice to have the help of Forum members and a dealer who appreciates and takes care of their customers.
Old 09-22-2014, 06:40 PM   #6
Slympicins's Avatar
On behalf of the rest of the folks, your welcome. We all have little issues we pass around to find out what everyone does to fix or mod it. Stay tuned.
Chuck and Joanne
Old 09-22-2014, 07:02 PM   #7
By its (Flush Floor) design it Must lift on the leading edge to (Come In).The (Rub Pads) will determin the (Angle) in which it (Comes In). Your Vertical seal problem is probably due to a (Gear/Tooth). I have (Been to the Mountain) in regards to (Super Slides)! Youroo!!
Old 09-23-2014, 10:30 AM   #8
I have a 2014 832 IKBS flagstaff TT. it has 3slides and the 2 back slides leak while pulling in the rain. Any one else have this problem?
Jonboyrutledge is offline   Reply With Quote
Old 09-23-2014, 03:22 PM   #9
None here. What are the details of these leaks?
Regards,
Wayne
Old 09-23-2014, 03:31 PM   #10
Water on the floor in front if both slides.
Old 09-23-2014, 06:50 PM   #11
Slympicins's Avatar
No problem here either. I just sprayed all my slide seals as well as all the rubber on the hatches. Cleaning the roof with Dicor cleaner and sealer this weekend.
Chuck and Joanne
Old 09-23-2014, 07:00 PM   #12
As someone in your other thread opined, it is probably water leaking past the seals around the slideout opening. The question is, which one of the 4 slides. If the water is pooliing on the water in front of the slides it coul be the front vertical seal. It could also be the top horizontal ("roof") seal especially if the trailer is typically tilted head down.
I would suggest a hose stream test on each seal separately. Start with dry seals and spray with a stedy fan spray of water and check the inside each time.
Note that while the trailer is moving it would be different since the opening would be flexing and thereby varying the seal between the slideout box and the side of the trailer. Conducting a static test would be the first test to indicate where the weak seal might be.
Regards,
Wayne
Old 09-23-2014, 07:16 PM   #13
I'll check that. Thnx.
Old 09-23-2014, 07:21 PM   #14
Slympicins's Avatar
Good call Wayne.
Chuck and Joanne
Old 09-23-2014, 07:31 PM   #15
I have a 27 rlws and can see daylight in front closet slide through top forward corner with slide in. Trailer has been out in torrential rains with slides out and in with no leaks. Haven't towed yet in rain but am worried about it. Anyone else with this trailer see this? You have to get on bed to look over slide to see it. Thanks, Dan
cub22908 is offline   Reply With Quote
Old 09-23-2014, 07:56 PM   #16
Slympicins's Avatar
Dan we have the 27RLWS but haven't noticed any leaks. I will take a look the slide this weekend and let you know. Pretty sure it's snug as a bug. Well...I'm hoping we are snug as a bug.
Chuck and Joanne
Old 09-27-2014, 07:28 AM   #17
Slympicins's Avatar
Got up on the bed yesterday and looked at the wardrobe slide. I didn't see any daylight coming through the top of the slide nor anywhere else.
Chuck and Joanne
Old 09-27-2014, 02:05 PM   #18
Thanks. It's something I better get taken care of. I'm sure while towing it will leak even tho it doesn't while stationary.
Old 09-27-2014, 05:28 PM   #19
Slympicins's Avatar
I bought some weather strip cleaner a few weeks ago and did all the rubber seals on slides and hatches. Seems to be working good. Left a good silicone feel on the seals and repels water.
Chuck and Joanne
Old 09-27-2014, 05:33 PM   #20
Slympicins's Avatar
Name:	ImageUploadedByForest River Forums1411857160.192141.jpg
This I what I used.
Chuck and Joanne
slide
