Old 06-03-2016, 01:38 PM   #11
Looks like the bumper has more "meat" attached to the frame than the brackets
2016 Flagstaff 27VRL with overloaded tires from factory
2015 Chevy Silverado
Paul GA is offline   Reply With Quote
Old 06-03-2016, 03:50 PM   #12
Bumper on mine has some crappy looking welds about 1/3 as long as they should be with poor penetration.
2013 Ram 1500 Laramie 5.7
2015 Flagstaff 27VRL
Riccochet is offline   Reply With Quote
Old 05-30-2017, 08:19 PM   #13
27VRL brackets under rear bumper
I mounted these there...
ID:	139603Click image for larger version
stevedfive is offline   Reply With Quote
Old 05-31-2017, 08:03 PM   #14
Stevedfive. I really like the tubes mounted near your rear bumper. Care to divulge how (and with what) you mounted these? Nice !
Harlan & Pattie in MD
2017 Flagstaff 832 IKBS
2017 F-250 Crew 4X4 6.2L
MHBroker is offline   Reply With Quote
Old 05-31-2017, 10:05 PM   #15
The are the Valterra 50"-94" Adjustable Sewer Hose Carriers. I just used one existing hole in each side of the frame and then drilled the second hole to match the carrier mount. I decided to add a second tube so I used some 1" aluminum "L" angle x 14" long to mount the second one. I think I used 1" and 1 1/2" x 3/8" bolts and lock watchers. If you need anything just let me know. I bought the L angle at Home Depot.
Old 06-01-2017, 08:01 PM   #16
THANKS for the info.
Old 06-02-2017, 06:03 AM   #17
jeff64's Avatar
Attachment 139698
I have the manual stabilizers and mounted a pair of the Sani-tube Super Slider (about the same thing) on the mounts where the electric stabilizers went. By fabricating a slightly longer plate for mounting, one of them holds a few 6 1/2' fishing rods.
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 06-02-2017, 09:33 PM   #18
Attachment 139698
Stevedfive. Thanks for the info. One additional question. Will these Valletta hose carrier accommodate your regular sewer hose while leaving the connector end intact....or will I need to remove the ends each time before storing hose? Thanks.
Old 06-02-2017, 09:38 PM   #19
Will the Valterra hose carrier accommodate your sewer hose with the connectors ends attached or do you have to remove those ends each time you store the hose?
Old 06-02-2017, 10:44 PM   #20
Yes. It will hold all the ends except for the big elbow end.
