05-31-2016, 06:56 PM
27VRL brackets under rear bumper
Does anyone know what these mounting points under the back bumper of my Super V 27VRL?
2016 Flagstaff 27VRL with overloaded tires from factory
2015 Chevy Silverado
05-31-2016, 08:49 PM
Who Dares, Wins
For a swing away grill?
Sent from my SM-G930V using Tapatalk
2015 Chevy HD D-Max
2022 Impression 315MB
05-31-2016, 09:00 PM
My Rockwood 2703ws has those brackets too; never could figure out for what.
Danny & Darlene
2002 Silverado 1500HD
2014 Rockwood 2703WS 'Emerald Pkg'
Days camped 2015=42 2014=48 2013=41 2012=47 2011=18
05-31-2016, 09:29 PM
We have the same thing on our 27rlws. Not sure what for? Wondered if I could use them for a bike rack or trailer hitch receiver.
Orval and Yvonne
2016 Flagstaff 27RLWS Emerald Package
2011 F150 SCrew XTR 5.0L 4x4
05-31-2016, 09:36 PM
They're on both sides so I was thinking a rack or casters so ya don't drag the rear
06-01-2016, 11:16 AM
The brackets are for mounting the standard rear stabilizer jacks if your TT doesn't have the optional power stab jacks.
2015 Ram 2500 CTD,CC,SB,4x4
2016 Rockwood 2703 Emerald Edition
Husky CenterLine TS Hitch
TST 507 TPMS
Progressive Industries EMS-PT30X
06-01-2016, 11:50 AM
Exactly right
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
06-01-2016, 04:27 PM
Ahh! Yes, I have power stabs. Wonder if adding some there would help rocking...
Thanks yall!
06-01-2016, 04:47 PM
IMO, the power stabilizers are too far from the axles, I'm getting ready to move mine inward not further out - you don't walk against the rear wall but you do between the tires and about halfway to the rear wall; Ever notice the locations of jacks on the newer 5th wheelers, right next to the tires..
Danny & Darlene
06-03-2016, 11:22 AM
You know, I have 27VRL as well, and was just looking at those mounts yesterday scratching my head.
They are welded securely to the frame. So, in theory, you could probably fab up a bike rack or something to make use of those mounts.
As for rocking. I put the strong arm bars on both front and rear power stabs. Made a world of difference. Coupled with X wheel locks and a couple scissor jacks mid frame we get no bounce or rocking.
2020 Ram 2500 Laramie Longhorn 6.4
2015 Flagstaff 27VRL
06-03-2016, 01:38 PM
Looks like the bumper has more "meat" attached to the frame than the brackets
06-03-2016, 03:50 PM
Bumper on mine has some crappy looking welds about 1/3 as long as they should be with poor penetration.
05-30-2017, 08:19 PM
05-31-2017, 08:03 PM
Stevedfive. I really like the tubes mounted near your rear bumper. Care to divulge how (and with what) you mounted these? Nice !
Harlan & Pattie in MD
2017 Flagstaff 832 IKBS
2017 F-250 Crew 4X4 6.2L
05-31-2017, 10:05 PM
The are the Valterra 50"-94" Adjustable Sewer Hose Carriers. I just used one existing hole in each side of the frame and then drilled the second hole to match the carrier mount. I decided to add a second tube so I used some 1" aluminum "L" angle x 14" long to mount the second one. I think I used 1" and 1 1/2" x 3/8" bolts and lock watchers. If you need anything just let me know. I bought the L angle at Home Depot.
06-01-2017, 08:01 PM
THANKS for the info.
06-02-2017, 06:03 AM
Attachment 139698
I have the manual stabilizers and mounted a pair of the Sani-tube Super Slider (about the same thing) on the mounts where the electric stabilizers went. By fabricating a slightly longer plate for mounting, one of them holds a few 6 1/2' fishing rods.
14K Equalizer
06-02-2017, 09:33 PM
Attachment 139698
Stevedfive. Thanks for the info. One additional question. Will these Valletta hose carrier accommodate your regular sewer hose while leaving the connector end intact....or will I need to remove the ends each time before storing hose? Thanks.
06-02-2017, 09:38 PM
Will the Valterra hose carrier accommodate your sewer hose with the connectors ends attached or do you have to remove those ends each time you store the hose?
06-02-2017, 10:44 PM
Yes. It will hold all the ends except for the big elbow end.
