Old 07-28-2019, 07:36 PM   #1
29RKWS fridge access with slide in
We are looking at this model and one of the items on our list is access to the fridge while traveling. Is it possible to get in the fridge with the slide in? Thanks!
dugwms is offline   Reply With Quote
Old 07-28-2019, 08:14 PM   #2
Nope. The slide needs to go out about 2'. When closed, it goes right up to the galley counter.
woo10-210 is offline   Reply With Quote
Old 07-28-2019, 09:22 PM   #3
Thanks!
Old 07-29-2019, 08:05 AM   #4
Looking at it another way.....
We had the same thing on our list but ultimately bought a floorplan (8529IKBS) with the same restricted refrigerator access. With the push of a button, the slide is out far enough in seconds to access to lower doors of our four door refrigerator. In two years it hasn't been a problem or an issue. The top doors (freezer) are accessible with the slide in so we'll often put a couple bottles of water in the freezer and we can have nice cold drinks whenever we want during our trips.
My point being... don't let refrigerator access (with the slide in) be the deciding factor of a floorplan you like.
Days Camped: '16=46 '17=30 '18=51 '19=42
Old 07-29-2019, 08:17 AM   #5
just a tidbit but you won't be accessing the refrigerator when traveling. you'll at least have to stop to get into the trailer!
we have the same issue. and it is not just the refrigerator. we can't get to any of the kitchen drawers or cupboards when the slide is in. where we notice it is not while travelling but when we are loading / unloading. we are in a storage facility and we have learned that we have to position the trailer just right in our space to allow us to extend the slides without hitting the trailers on either side of us while we load / unload.
is it an issue? yes. is it a showstopper? no.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
Old 07-29-2019, 02:58 PM   #6
Multi-Slacker
If you otherwise like the floorplan, there is plenty of room for coolers that should cover all needs for the travel day.
2017 Forest River Sonoma 280RKS
2018 Silverado 2500 HD 6.0L, 4:10 rear
Prodigy P3 Brake Controller
Andersen WDH / 2700 lb 2.5" Receiver
CurtPutnam is offline   Reply With Quote
Old 07-29-2019, 06:52 PM   #7
We looked at it tonight. It is 30 amp and only has a 13500 AC. Not sure how well that will work with an RV that big.
2015 Chevy 2500HD
2016 Flagstaff 26RLWS
2016 Apricot Labradoodle "Lilly"
Old 07-29-2019, 07:12 PM   #8
Likely OK in more northern states but probably not good in FL, TX, AZ, etc....
Old 07-29-2019, 07:18 PM   #9
Multi-Slacker
0Ours only has a 13.5. In 100+ weather, it does not cool down instantly. Does get things to tolerable rather quickly. We try to head higher to avoid such temps.
Old 07-29-2019, 07:29 PM   #10
BillyBass's Avatar
Have a question plug my frig in about 5 hrs ago and it still isnt that cold.The outside of it was in direct sun light .Can that be part of the problem.The condenser is warm.Also it was on a 15 amp breaker so i switch it to a 30 amp will that make a difference
2019 Flagstaff 26 RBWS
2005 GMC Sierra 1500
2019 camp 17 nites. Bill ,Alley and Sierra
BillyBass is offline   Reply With Quote
fridge, slide
