Old 08-05-2014, 01:23 AM   #1
ready2retire's Avatar
3 slides 'dead'
After a 3 week rest following a 10 day camp, none of the 3 slide outs on my 5th wheel works. Not even a click. All other utilities works fine. Batteries ( 2 x in parallel) fully charged. Tried to locate in-line fuses etc. but no luck. [Flagstaff Ultra Light 8528 RSWS 5th wheel]. Any suggestions ? and thank you !
2013 Flagstaff Classic Super Lite 8528 RSWS
2007 GMC 2500HD Duramax Diesel
Nobody am perfect, I is trying to are . . .
ready2retire is offline   Reply With Quote
Old 08-05-2014, 06:02 AM   #2
Are they hydraulic slides? If so, look for a 15 amp in-line fuse near the pump and replace if blown. It powers all the hydraulic system electronics. It may be hidden behind other wires and is usually inside a plastic holder with a cover.
2014 Blue Ridge 3715BH <- Read the saga
2013 Sierra 3500HD Denali CCLB DRW 4x4 Duramax w/ Reese 20K
USN Retired (26 years), but not Retired retired
Home Port Orlando
Narboza is offline   Reply With Quote
Old 08-05-2014, 06:13 AM   #3
Plain Old Member
Being Flagstaff, should be 2 Lippert electric slides and 1 BAL Accuslide on the wardrobe in that model. In that case, my guess is the fuses to the slide motors should be in the main 12v fuse panel, which in most cases is next to or part of the main power center. Not really sure on the Flagstaff. Every electric slide I've had in the past, the fuse was amongst all the others in the panel.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 08-05-2014, 06:53 AM   #4
Mr. Dan's Avatar
My Wildcat has a 20 amp fuse in position 6 for slides.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 86; booked = 0
Old 08-05-2014, 07:23 AM   #5
On my travel trailer they are not in the fuse box but are in-line fuses under the trailer just aft of the left A-frame side. The wire is directly connected to the battery.
Yours being a 5th Wheel does not have an A-frame so if they are not in the fuse box I would try and trace wires back from the battery to see if you have any in-line fuses that look something like this:
Regards,
Wayne
2014 Flagstaff Super Lite 27RLWS Emerald Edition | Equal-i-zer 1200/12,000 4-point WDH
2010 GMC Sierra SLE 5.3L | K&N filter | Hypertech Max Energy tune | Prodigy P3
Wmoses is offline   Reply With Quote
Old 08-06-2014, 11:32 PM   #6
3 slides -mystery resolved!
Thanks to everyone who replied to this thread. I phoned the service manager at the Flagstaff Dealership, who pointed out that there are 2 breakers situated just behind the battery, and to the right of the battery cut-off switch. [ See pictures ]. These breakers' reset buttons are NOT visible (pointing downwards), but can be felt as a small button at the bottom of the breaker. I just pushed the button, it reset and my slides were revived!. Thanks Sheldon at Paradise RV in Leduc for your help.
Old 08-07-2014, 07:37 AM   #7
I suspected that is where you would find the fuse (in your case breakers). Glad to see it resolved.
Regards,
Wayne
slide, slide out
