Old 11-20-2014, 05:33 PM   #1
kopy kat's Avatar
3-step entry unit broken
does anyone know the brand of and where to get replacement "rivets" for the 3-step entry unit on the Flagstaff?
The top step left side rivet broke off...sigh...
Thanks,
Larry
kopy kat is offline   Reply With Quote
Old 11-20-2014, 05:37 PM   #2
jtstromsburg's Avatar
Thanks,
Larry
Believe I've read that many have drilled the rivets out and replaced them with grade 8 nuts and bolts. Much stronger
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 11-20-2014, 05:40 PM   #3
MC9
While you're at it, grind off all the rivets, drill the holes to 5/16" and install short bolts and locking nuts before you fall and break your neck.
MC9 is offline   Reply With Quote
Old 11-20-2014, 05:44 PM   #4
Yes, just drill the rivets out with a sharp 5/16" bit and get some 5/16x1 gr 8 bolts and locknuts. Did that the day we got our 5er home when it was new.
Old 11-20-2014, 05:47 PM   #5
kopy kat's Avatar
thanks for the info--sounds like the way to go...new bolts!
