Old 04-09-2016, 10:04 AM   #1
831BHDS Flagstaff - Forest River 2 questions
2014 831BHDS unit
Its in storage but I need to know:
1. What heater Suburban Water Heater Anode Rod model I need?
2. What water filter model do I need?
2014 Flagstaff 831BHDS
2010 Ram 2500 Cummins 4.10s - Superchip'd
Built-in Controller
Hellwig Sway Bar 7272
Equalizer Hitch system
Long Islander is offline   Reply With Quote
Old 04-09-2016, 10:30 AM   #2
SeaDog's Avatar
I would think you could find those part numbers in your manual
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 04-09-2016, 12:26 PM   #3
Doesnt help when the manual is with the camper.
Anyone know what model parts I need??
Built-in Controller
Old 04-09-2016, 12:47 PM   #4
The Suburban manual lists the anode rod for their water heater as part # 231624.
It appears that number has been superseded several times with 232767 and 232768 both of which seem to be readily available on the internet.
If the water filter is the factory installed FR-1 (Water Pur) it will only accept the OEM cartridge # KW1
Days Camped: '16=46 '17=30 '18=51 '19=50
Old 05-24-2016, 11:52 AM   #5
I pulled mine out and took it in foe a replacement. Fast and easy cost 12.00, oh My 1st time and bleed the pressure off your tank! Thank God it missed me as it shot out!
tmsimmons56 is offline   Reply With Quote
flagstaff, forest river
