Old 07-08-2017, 01:17 PM   #1
AC Unit
I bought an 8528IKWS 5th wheel this past winter. This is 1 st trip out with over 85 deg. Weather. The AC unit seems not to be cooling the unit. It's over 80 deg. Inside the unit Are the units to small for this camper or is the CandlouraAC unit not working. The unit is 3 years old.
dave g is offline   Reply With Quote
Old 07-08-2017, 05:38 PM   #2
jtstromsburg's Avatar
Does the air feel cold at vents?
There are many threads about AC's not coping campers enough. It's entirely possible the AC unit is shot. It's also possible it's working the best it can.
Many variables
*Sun/shade
*Run it on high fan setting and direct dump feature if available
*check ductwork for leaks. Many of us found leaks at vents and even at the AC unit itself.
*make sure filter is clean
Hope this helps a bit and you can get cooled down soon
Many times my 40' fiver doesn't cool down the first day until after dark, even with two AC's and some shade.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 07-08-2017, 07:31 PM   #3
Also, if you have a ceiling fan, don't run it with the AC on. It interferes with the warm air at the intakes.
2015 Tracer ultra light executive edition 3200bht
2007 Dodge Ram 3500 Cummins 6.7, Dually, crew cab, long bed
SilverArrowPro is offline   Reply With Quote
