Old 04-16-2018, 01:10 PM   #1
Macdonald's Avatar
Adding Electric Heat 832OKBS
What should I order to add heat capabilities to my a/c unit in the bedroom? Is it a heat strip kit and fairly easy to add? Thanks in advance! Curtis
2017 Forest River Flagstaff
832OKBS Classic Super Lite
2018 Dodge Ram 3500 Dually - Tow Vehicle
Home Base - Celina, TX
Macdonald is offline   Reply With Quote
Old 04-16-2018, 01:33 PM   #2
Fulltime family RVer
I think it depends on your air conditioner and if it's prepared for a heat strip to be added.
As part of my new camper purchase, I requested a 3rd A/C with heat strip. They missed the heat strip part and ended up having to order it after the fact. This particular model, it IS just a plug in of the heat strip module and then a replacement thermostat (both ends- the part that interfaces with the camper wiring and the thermostat itself).
But, I've read that there are some models that it isn't as easy.
If I were you, I would find out the manufacturer of your air conditioner and contact them with your serial number to find out what it takes.
Old 04-16-2018, 01:42 PM   #3
Macdonald's Avatar
That's what I'll do. I believe that the living area has the heat strips but the bedroom does not, so I will look at the manuals tonight or look at the unit itself. I would rather run the central heat and lay off the propane usage, afterall, when you are paying b the night and have electric expenses included, why not use the central heat! LOL
Old 04-16-2018, 05:20 PM   #4
The one I installed just plugged in.
Rockwood 2604WS
Ford F250 Diesel
Blue Ox Sway Pro
allenb12 is offline   Reply With Quote
Old 04-17-2018, 07:58 PM   #5
The experience I have had with the add on heat strips just suck. Not much heat at all. Just get one of those ceramic heaters works for me...
wcrafter is offline   Reply With Quote
electric
