Old 02-14-2015, 02:48 PM   #11
Originally Posted by Denny and Suni View Post
With the second battery we have boondocked 7 days without a charge. (We do have two generators.) The 21FBRS with LED lights puts little demand on the batteries.
When (or if?) this snow every quits, I might just grind off the two fore and aft L pieces of the existing battery bracket. That should get me another two inches or so of overall width to accommodate two regular battery boxes. Plan B will be to build a plywood box to fit.
Thanks for all they replys!
2015 Flagstaff 21FBRS
2012 Silverado 1500 LT Ext Cab 5.3L 3.08
Blue Ox SwayPro 550
danking49 is offline   Reply With Quote
Old 02-14-2015, 03:00 PM   #12
Happy Campers
Denny and Suni's Avatar
Easy Mod
We used the battery box that came on the trailer and bought the other standard stock off the self from Menards (like Home Depot). Did not need to cut or grind handles or box. More or less a drop-in.
BTW: you can see the snow in the background of battery box photo. More on the way.
"I went to the woods because I wished to live deliberately...and not, when I came to die, to discover that I had not lived." H. D. Thoreau
2012 Nissan Frontier 4X4 Crew Cab Longbed
2014 Flagstaff 21FBRS
Some Yorkies
Denny and Suni is offline   Reply With Quote
Old 02-14-2015, 05:07 PM   #13
Doubling up Batteries
I don't know if this will help but we added two "Interstate" 6-V Batts (GC2-XHD-UTL) to our Flagstaff V-Lite 26WRB. Our dealer supplied the heavy duty opaque plastic box which has inside dimensions of 21" X 7,1/8" X 11,1/2"deep. The batteries are 10,1/4" (2) X 7" X 11,14"high O/A. They are a very nice tight fit but require a battery carrying strap to remove. I am attempting to attach photos but have not got the hang of exactly how to do this from a Mac but will give it a try.Click image for larger version
If they attached they are mostly self explanatory but the open box does show just one 12 Volt batt. This is just an old one I use just for storage. The two 6 Volt units are showing on floating charge in storage.
I modified the lid closing arrangement as the dealer had just used plated sheet metal screws. It can be seen that I used 1/4" stainless threaded inserts. On the lid I use four SS 1/4" bolts with flat and lock washers.
Hope this is of some help.
kcdelan is offline   Reply With Quote
Old 02-14-2015, 05:13 PM   #14
Witch Doctor's Avatar
Looking to pics and ideas for adding a second battery to the tongue of my 21FBRS. Space is a little tight on this small-ish travel trailer and two group 24 battery boxes simply do not fit. Trying to use the existing battery rack but starting to think this project will involve having something larger welded up.
I think a couple day's ago this guy built a battery box to fit on his tongue and did a great job. and bolted it to the frame. used plated steel
Coachmen M/H
Concord
2018 / 300 DSC
Old 02-14-2015, 07:16 PM   #15
Do you run 2- 6V golf cart batteries, or just carry a spare 12volt??
Henboy is offline   Reply With Quote
Old 02-14-2015, 07:53 PM   #16
I use 2 X 6V Golf Cart Batteries ("Interstate" GC2-XHD-UTL) and just carry an older 12V Deep Cycle in the back of my truck as a spare.
Old 02-17-2015, 12:49 PM   #17
You want to Connect in Parallel. Both batteries should be the same type and capacity.
By connecting in Parallel you are doubling the capacity (amp hours) of the battery while maintaining the same voltage of one of the individual batteries.
A jumper wire between the positives of both batteries and another jumper wire between the negatives of both batteries. Connect your positive and negative wires to the same battery to run to your application.
pauljackie is offline   Reply With Quote
Old 02-17-2015, 12:57 PM   #18
All good info from "pauljackie". I would only make one further point (from bitter experience). In addition to both batteries being of the "same type and capacity" I would also like to add that they should be from the same manufacturer and have the same manufacturing date or lot number.
Old 03-06-2015, 05:15 PM   #19
I turned one battery box front and one back. The tops miss each other then.
jimc0000 is offline   Reply With Quote
Old 03-07-2015, 06:47 PM   #20
The first thing I did when I bought my 21FBRS was purchase two Trojan deep cycle 6 V batteries and put them in series. Trojan batteries are the best, used in golf carts and lots of industrial equipment. I have gone a week with out charging my batteries.
SPARKEY BOB
IBEW LU 613 Atlanta
Micro Lite 21 FBRS
Toyota Tundra
SparkeyBob is offline   Reply With Quote
battery
