Old 08-13-2015, 08:25 PM   #1
tahoe1840's Avatar
AGM or Gell
Cutting to the chase here. I am looking for other opinions on AGM batteries compared to Gell style. We are going to upgrade our cheap flood wet cells for either AGM or Gell. I have search the forums but cannot really find any good posts comparing the two so am looking for some ideas and thoughts. Which tends to have a longer service life? Which typically have more Amp Hours? Type 24 or Type 27? I think either will fit my vented battery boxes. Thank you ahead of time.
tahoe1840 is offline   Reply With Quote
Old 08-13-2015, 08:36 PM   #2
mud yapster's Avatar
AGM is what you want, they are designed to handles same charging characteristic as your cheap flooded battery.
Gel cells are more critically charged and your RV charge system will cook them off and destroy them.
You don't need to worry about venting AGM batteries and they can even be layed on there sides or on there ends and used if you want. As long as you don't run them down below a 50% charge before recharging them they will last a long time. I have 3 12volt for a total of 435ah on 520 watts of solar for my boondocking.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 08-13-2015, 08:46 PM   #3
rsdata's Avatar
good info here
Absorbent Glass Mat (AGM) Battery Information - Battery University
Too much of anything is bad, but too much good whiskey is barely enough. Mark Twain
2014 Shamrock 183
Old 08-15-2015, 11:10 PM   #4
Vedy Interestink
To quote Col. Klink and add my thoughts. One of my concerns on purchase of a V-Lite was only one battery. I'm interested for sure.
My duramax is about due for batteries again also.
whatsupchuck is offline   Reply With Quote
Old 08-20-2015, 12:18 PM   #5
tahoe1840's Avatar
Thanks Mup, I guess there are not too many out there with opinions, yours was a big help.
Old 08-20-2015, 12:29 PM   #6
DAISY BOYKIN's Avatar
Switched to AGM
I switched to series 31 AGM battery about 1 1/2 years ago. Had to get a larger battery box. Does not require any service, doe not require any venting. Still one heavy battery!!!! About 1/2 again the size of battery that came in my fifthwheel.
Sams Club has the best prices on AGM batteries
I paid somewhere around $175.00 for the Group 31.
Sid, Lois & HRH MISSY Terrible 3s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS 6.7L/SWD/6R140/BFT
DAYS CAMPED 2018 60 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 09-12-2015, 10:09 PM   #7
I know it's a bit late to add, but, if AGM doesn't need vented etc., why not move it inside close to the convertor? This is just a thought as front kitchen has cabinet space down low and would not need any cable addition or battery box.
Charles & Martha Myatt
2009 Duramax w/Transfer Flow Fuel Tank
2016 Flagstaff V-Lite 30WFKSS
Almost South of the Border
Old 09-12-2015, 10:37 PM   #8
trbomax's Avatar
Please let me know where I can buy cheap floddedcell batterys Seriosly thoug.AGM is a good choice if the batts are in a hard to reach spot or a person is too lazy to keep after lead acid batts.I think that sometimes bassic is better and Ive never found a good reason to spend the extra $ for a tricked out agm battery.Lead acid for me!
trbomax is offline   Reply With Quote
Old 09-14-2015, 08:47 AM   #9
tahoe1840's Avatar
Daisy, hmmm Group 31, I'll look into that. I'm finding it real hard to even find AGMs strictly for RV use anyway, it appears these days that Marine/RV is what is out there, based on reading however I find that these combo batteries should be avoided wet or AGM. Pretty confusing I must say but thanks to all for the suggestions.
