your choices depend on how much you need for you tires. you didn't mention the psi needed for you tires. the more pressure you need to fewer choices you will have and the more dollars you sill spend. your next choice is whether you need a 12 volt dc compressor or 110 volt ac compressor. if you are on the road do you 110 vac source (ie generator)? if you get a 12 vdc compressor make sure you get connect the compressor to a 12 volt source (battery) and have long enough hoses to reach the tires.
personally we have the viair 450 rv compressor as we need 110psi. it has an extension hose that allows me to connect the compressor to the truck battery and I can extend the hoses to reach the tires.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
