Old 04-23-2012, 09:53 PM   #1
Another question fron a newby. How level is level?
Know that my camper should be level for the fridge to work, but how level. It's fine front to back here in the driveway, but side to side is off by 1/4 bubble. I want to turn on the fridge for our first trip this weekend and really don't want to have to hook up to level the camper. Is this close enough? Also, I have a battery disconnect switch. Should I leave it on or off when connected to power for an extended time? Thanks.
2013 Flagstaff 27RLWS
2014 Ford F150 Ecoboost
30 nights in 2015 so far
roanmountaincampers is offline   Reply With Quote
Old 04-23-2012, 10:14 PM   #2
jonnys_walkers's Avatar
A bulls eye level in the bottom of the fridge.
Never enough camping!!
jonnys_walkers is offline   Reply With Quote
Old 04-23-2012, 10:28 PM   #3
As long as you don't fall out of bed...... No really. The fridge can be off a little. If you get down to it, and the floor is level, the cabinets may not be, and neither the fridge. Get as close as you can, in a reasonable amount of time. A lot of people, me included, run their fridge on propane while towing, so how level is that? True, the fridge should be level to be the most efficient, and work at it's best, but nothing to loose sleep over.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 04-23-2012, 10:36 PM   #4
Dave_Monica's Avatar
If you're plugged into 120V, you needn't disconnect the battery. The camper's converter will keep the battery fully charged. I store our camper at home and it's plugged into 120V year-round.
Dave
Old 04-23-2012, 10:37 PM   #5
Triguy's Avatar
Dometic suggets leveling so that it's comfortable to live.
Leveling the refrigerator
"leveling is one of the requirements for proper operation with absorption refrigerators. To ensure proper leveling the vehicle needs to be leveled only so it is comfortable to live in (no noticeable sloping of floor or walls).
Any time the vehicle is parked for several hours with the refrigerator operating, the vehicle should be leveled to prevent this loss of cooling.
If the refrigerator is operated when it is not level and the vehicle is not moving, liquid ammonia will accumulate in sections of the evaporator tubing. This will slow the circulation of hydrogen and ammonia gas, or in severe cases, completely block it, resulting in a loss of cooling.
When the vehicle is moving, the leveling is not critical, as the rolling and pitching movement of the vehicle will pass to either side of level, keeping the liquid ammonia from accumulating in the evaporator tubing."
Disconnect
As for the disconnect, leave it on so the batteries can charge. This assumes you have a three-stage charger with your converter. Almost all newer trailers will, but check your manual. It's all there.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 04-24-2012, 06:16 AM   #6
Thanks for the advice. Hopefully will make our first trip this weekend. Looking forward to finally using the trailer.
Old 04-24-2012, 06:36 AM   #7
TURBS's Avatar
And have fun darn it!
Old 04-24-2012, 06:42 AM   #8
showtime0022's Avatar
Turn your fridge on one day before leaving, helps cool it down. I leave mine on during towing.
showtime0022 is offline   Reply With Quote
Old 04-24-2012, 06:52 AM   #9
Triguy's Avatar
Kb,
Have fun with your first trip. FWIW, the first trip in a new trailer is a great way to shakedown all your systems and the procedures you need to know. If you run across anything that you want help with, and have an Internet connection, be sure to post. I'm sure you'll get help in "real time".
Scott
2012 Shamrock 233S
Old 04-25-2012, 11:03 PM   #10
flc
flc's Avatar
That's what I do.
2013 Bullet 248 RKS (soon)
2012 F150 SuperCrew w/Ecoboost 3.5L
flc is offline   Reply With Quote
