Old 10-11-2018, 08:01 PM   #1
Antifreeze Inlet to Antifreeze
I have three inlets on my camper.
1. City Water
2. Blackwater flush
3.Antifreeze inlet to antifreeze
Can someone explain how the antifreeze inlet works?
I have looked all through the manual and tried finding out how it works on youtube but have founding nothing regarding this inlet. I would appreciate any help someone can send my way. Thanks, Keith
Skeeter63 is offline   Reply With Quote
Old 10-11-2018, 08:15 PM   #2
I'm guessing the valves it's talking about are the ones on the water heater.
Iwritecode is offline   Reply With Quote
Old 10-11-2018, 08:27 PM   #3
You are correct. My question is how does the inlet work? I'm guessing you hook a hose to the inlet and the other end in a gallon of antifreeze. In order for this to work do you just turn the pump on? Have never seen this on a camper before and want to make sure I know how it works. I'm very paranoid. Seems every time I touch something on this POS I break what ever I'm trying to work on.
Old 10-12-2018, 11:28 AM   #4
Smile
You are correct in your last posting. Turn valve and place hose in gallon bottle of drinking water antifreeze. The pump will pull from the bottle and discharge through the water lines. When done, place the valve in its original position and that returns the pump suction to the water tank.
l001952119 is offline   Reply With Quote
Old 10-12-2018, 11:40 AM   #5
Kaadk's Avatar
You'll have two sets of valves to deal with. One set at the hot water tank to put it in bypass, the other set will be between the pump and the freshwater tank. Note: depending on unit, these valves might be accessible in the wet bay. If you don't have a Wet bay, they're probably right by the pump.
You bypass the hot water tank like you always would have. At the pump, you close the valve to the fresh water tank, and open the valve on the hose that runs to the inlet. Then, you stick a hose from the inlet into the anti-freeze and run the pump till you get pink in the lines.
Old 10-12-2018, 12:56 PM   #6
AKA: 'tiredTeacher
awellis3's Avatar
Nope, it's the one that shunts the water pump's intake from the freshwater tank to the antifreeze inlet.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 10-12-2018, 02:28 PM   #7
Thank you, I really appreciate your help.
Old 10-12-2018, 02:34 PM   #8
So,the valve you are talking about be at the pump or the valve that by passes the water heater?
Old 10-12-2018, 02:35 PM   #9
Thank you
Old 10-12-2018, 02:36 PM   #10
Thank you.
antifreeze
