Has anyone put, or, tried to put a 72X80 king mattress in the 72 inch slide? Floorplan example would be 831rlbss or the 30wfkss where the slide is big enough numerically but has little end tables on each side of the queen.
Thought is to cut down the end tables flush with the bedframe and add plywood base to match the mattress in width. Our present rig had to small a base and I added to the edge of the base and covered the whole thing with a vinyl material to aid in sliding the mattress. Present slide is 63 inch with a 60 inch queen and nose to the walls.
