Old 05-11-2015, 08:08 PM   #11
Henboy, That mod looks great! I hope this is something that we can eventually do with our nighstands. Where did you get the door fronts?
2011 MicroLite 23LB
2012 Ram 1500 Crew Cab
zinger60 is offline   Reply With Quote
Old 05-11-2015, 09:11 PM   #12
Drawer fronts were ordered direct from Forest River.
I used the same fronts as furnished on the kitchen cabinets. They are pre-finished, but a bit too wide to fit the nightstand opening.
Cut them down to the width to fit the night stand. Self closing hinges from Home Depot.
We converted both sides. The curb side has water fill lines running thru it. Just caulk/seal around the openings where the lines come thru the wood and carpet.
There will be extra slack in the electrical lines when you move the plugs inside the opening...just push the wire down into the pass thru and secure.
The extra space is very useful, we use it every night.
We also converted the "fixed" door front near the floor, below the radio, to a hinged door (It had 4 hinges permanently fastening it to the cabinet frame). I just removed 2 of the 4 hinges and added a knob. All the manuals, instructions and paper work now go in there.
Have fun!
Henboy is offline   Reply With Quote
Old 05-26-2015, 08:19 AM   #13
I also found some baskets about the size of half of the top of the nightstand. then got 2 pieces of trim of any kind and nailed them into the top to create a slide free zone for the basket in the corner. Holds my books or whatever when in transit.
2014 Flagstaff 21FBRS
2013 Toyota Tundra 5.7
Skeetzee is offline   Reply With Quote
bed, beds
