Old 02-14-2016, 09:21 PM   #11
SeaDog's Avatar
My issue was the smoke but I was inside my shop. For flames to reach the awning it would really have to be a big flame and if so just shut the lid. When I cook steak I have the lid shut anyway. I really don't think flames to the awning are an issue. IMHO
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 02-20-2016, 11:41 PM   #12
aufinger's Avatar
You don't have to mount the frame that came with the grill to the camper. You can turn the frame 90 degrees and place the grill on a table or on the ground. I put mine on the ground and anchor it down with a couple of tent stakes. The attached picture is not a picture of my grill. I use a 15 foot extension hose to move the grill away from the camper.
aufinger is offline   Reply With Quote
Old 02-21-2016, 06:21 AM   #13
We have the slide mounted grill & small work table attached to the side of our IKWS8528 (included from the factory) and have used it many times with and without the awning extended. No problem----works perfectly.
2015 Silverado gas ext cab 2500
2014 Flagstaff 8528IKWS🇺🇸
greymedic is offline   Reply With Quote
Old 02-21-2016, 07:01 AM   #14
Georgia Frog Rally 2018
aceinspp's Avatar
Originally Posted by steeljag View Post
We have never used it (still in box). I just don't like the idea of grilling against the side of the TT. The heat / smoke created (burgers) then becoming stuck under the awning and getting into the camper, etc.
I normally grill from on top of the picnic table, our camping table, tailgate, anywhere with more air movement.
Enjoy your trip!
X 2 I got credit for mine when I bought tt told them to keep it. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
Old 02-21-2016, 07:43 AM   #15
Canadian Member
itat's Avatar
We have never used the Sidekick grill they came with both our trailers. There shouldn't be any problem with flames or heat but I'd rather not have the smoke and potentially grease getting on the underside of the awning.
We bought a Weber Q200 (now called the 2200) that has a larger cooking surface and I set it up on this aluminum collapsible table away from the trailer.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
Old 02-21-2016, 07:47 AM   #16
When we bought our Jayco moho one of those was included with a quick disconnect hose. We used it for 2 years and no problems, even in the rain, I grilled with the awning out. What I did not know, was that it could sit on the ground or a table with the included bracket. The manual did say not to use under awning!!!!!!!!! I am the designated cook on every outing, gives DW a break, and I am too clumsy to cook in the kitchen. So if you have that setup or get one, just use it and enjoy, even if it is raining.
shortkid is offline   Reply With Quote
Old 03-01-2016, 10:11 PM   #17
We ditched the propane grill will use the propane connection for a propane fire pit. Going with a Green Mountain Grill Davey Crockett pellet grill/smoker (runs on 12v or 110v) Our Daniel Boone at home is awesome.
FlagstaffT23FBSOwner is offline   Reply With Quote
Old 03-01-2016, 10:57 PM   #18
Have used an RVQ on the side of our 2 Flagstaff trailers always with the awning out and have had no problems with the heat or smoke damaging anything. Those that don't recommend using them under an awning are just blowing smoke. Pun intended!
Old 03-01-2016, 11:28 PM   #19
aufinger's Avatar
While at Atlanta Motor Speedway this past weekend, I came across a gentleman who had his grill attached to a swinging arm that was bolted to his rear bumper. His camper was a FR and he said it came with the camper. When the grill is positioned to the front of the camper, it's right there by the outside kitchen.
Old 03-04-2016, 05:56 PM   #20
mike.t's Avatar
Originally Posted by txredfish View Post
When I had my PDI, the dealer tech said it was OK to use the grill under the awning while the awning was out. But when I read the owner's manual it cautioned against this practice. I would think this could be dangerous due to flames possibly hitting the awning. I prefer not to do this so I guess I will purchase an extension LP hose.
Any thoughts on this..........
Flames??
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
propane
