Old 06-01-2014, 01:17 PM   #1
Timex's Avatar
Awning Lock
What about this Old Coot, will this work to keep the awning from unraveling while traveling? I figured you'll have something similar.
http://blog.goodsamclub.com/wp-conte...wning-Lock.jpg
Looks like a gatepost latch that is mounted on the awning arm and the latch slides into the hole in the roller tube. The latch is tie wrapped to keep from vibrating unlocked. Probably have to stand on a step ladder to unlock it unless you're 7' tall.
2012 Flagstaff V Lite 30 WRLTS
2005 Dodge Ram 2500 5.7 Mag Hemi 3.72 Rearaxle
Nights camped 2015 = 23
Nights camped 2016 = 25
Nights camped 2017 = 13
Nights camped 2018 = 3
Timex is offline   Reply With Quote
Old 06-01-2014, 01:22 PM   #2
Saw that, the only problem is how do you get up there to engage it and tie the wire on it? I made a tie rod for mine which I engage standing on the ground.
Name:	Alum tab for awning lock.JPG
ID:	54019   Click image for larger version
Name:	Alum tab, 3-8 x 1-2 ss bolt, washer & nyloc nut.JPG
ID:	54020   Click image for larger version
Name:	Awning lock top close up.JPG
ID:	54021   Click image for larger version
Name:	Bottom hook unlatched.JPG
ID:	54022   Click image for larger version
Old 06-01-2014, 01:34 PM   #3
DaGrinch's Avatar
Hey OC, does the bolt in the tie rod just screw into the awning groove? If not, do you have a closer picture?
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life........MOST of the time.
DaGrinch is offline   Reply With Quote
Old 06-01-2014, 01:40 PM   #4
Timex's Avatar
It's never happened to me (KNOCK, KNOCK) but how common is the awning unraveling during transit?
Old 06-01-2014, 01:41 PM   #5
I just stick my awning rod in hole up there and and then use 2 velcro straps and snug it to the awning support bar, no fuss no muss. It can't rotate. Plus my awning rod is right there where I need it when I unfurl...
kamu is offline   Reply With Quote
Old 06-01-2014, 03:23 PM   #6
No, you have to measure very carefully and drill a 5/16" hole in the end cap so it aligns with the slot where you slide the sunscreens in and then tap the hole & slot to 3/8-16 unc.
Old 06-01-2014, 03:33 PM   #7
Herk7769's Avatar
Soon after I put "Turb's Lazy Man Awning Mod" in, I was sitting in the truck getting ready to pull out and I looked in the passenger side mirror and saw the awning extending. Turns out I was sitting on the remote I left in my pocket.
Had I not spotted it I would have certainly lost the awning on the drive out of the campground.
Could have used OC's mod that day!
HAM CALLSIGN - KC3FFW
Old 06-01-2014, 03:38 PM   #8
Recall installation of said lock being offered in Goshen last year.
Old 06-01-2014, 03:44 PM   #9
Herk7769's Avatar
<sigh> Was a one armed paper hanger last year.
Too bad you won't be there this year.
Cleaned out the garage today and found my tap box.
Maybe this week?
Old 06-01-2014, 03:48 PM   #10
Maybe this week?
Do you have one of my locks?
Old 06-01-2014, 03:58 PM   #11
Herk7769's Avatar
I do. It followed me home from Goshen last year.
Old 06-01-2014, 06:28 PM   #12
DaGrinch's Avatar
Thanks. Appreciate the info.
Old 06-01-2014, 07:08 PM   #13
The Jayco class C I had in the 90's, had knob locks to keep the awnings from opening unexpectedly. When we picked our trailer up last week, the guy that did the walk through, said I don't need them on our power awnings. Is he a great big fibber?
katkt is offline   Reply With Quote
Old 06-01-2014, 07:12 PM   #14
Timex's Avatar
I bet he said your bicycle could pull your trailer with no problem!
Old 06-01-2014, 07:20 PM   #15
He speaks with 'forked tongue'
Old 07-01-2014, 03:57 PM   #16
After a trip this last week to Arkansas when I got home I noticed my awning out at the top about 3/8"maybe I did not get the awning closed all the way abut I beleive it came out while traveling.
Just wondering about the measuring carefully I know it needs to be centered in the hole but with the way the end cap on the awning is made how do you measure carefully to get the end cap cut to center the hole?
2003 Dodge Ram 2500 5.9 Diesel
2014 Rockwood 2608WS
Big Paul is offline   Reply With Quote
Old 07-01-2014, 04:04 PM   #17
I used a combination square, found the center of the slot, turned the combo sq. around and marked and center punched the sloping surface of the end cap. Started an 1/8" drill bit perpendicular to the surface and drilled the hole. Took the 5/16" bit and drilled parallel to the slot in the tube. Helps if you back the 1/8" bit out and force it parallel to the slot also.
Old 07-01-2014, 04:10 PM   #18
Thanks OC I can follow that. I am making the lock today. Need to drill hole for the bolt.
Old 07-01-2014, 04:50 PM   #19
Once you get the hole drilled and tapped, I took my Dremel and ground a flat around the hole so the ss nyloc nut would set flat.
ID:	56910   Click image for larger version
ID:	56911   Click image for larger version
Name:	Tab ready for locking rod hook.JPG
awning
