Old 08-24-2015, 08:38 PM   #51
redcloud1's Avatar
I wanted to see if anyone has a furion camera kit that would be interested in trading it for the solar panel. We don't dry camp and really won't use the solar panel.
redcloud1 is offline   Reply With Quote
Old 08-25-2015, 07:55 AM   #52
ElShamardo's Avatar
I purchased one with my new windjammer and am very disappointed. It has a poor wireless connection most of the time and is black screen station no connection, the frame rate about one a second when it does connect. Not great video quality. I like the small monitor size but wanted to add a side camera but the camera orientation setting on the monitor only does 180 and mirror and not 90.
James & Kathi
Trailer: Rockwood 8299-BS 5th Wheel
Truck: Ford F250 4WD 6.7L King Ranch
Austin Texas - Live Music Capital of the World & Home of the Longhorns!
ElShamardo is offline   Reply With Quote
Old 08-25-2015, 08:54 AM   #53
redcloud1's Avatar
I see that a lot of members are saying that the quality of the system is not very good. You would hope that they would upgrade the camera system and its wireless capabilities so that it would perform better.
Old 08-27-2015, 05:42 AM   #54
ejknight's Avatar
I found, through the forums, that the Furrion unit had a mixed bag of reviews and it seems that a lot of complaints about signal quality were the main issue. After seeing one in action on a friends TT I opted to NOT purchase it and we went with the RVS-CW-CAM from rearviewsafety.com. The unit is 299.00 in price but it functions very well on my 31 ft TT. Thats my $.02.
2015 Ram 1500 5.7 V8
2014 Rockwood 2703WS
Days Camped in 2016: 34 (A New Record!!)
Days Camped in 2017: 25
Days Camped in 2018 - Not Nearly Enough!
ejknight is offline   Reply With Quote
Old 08-27-2015, 06:38 AM   #55
Blog: RVroadtripper.com
hbillsmith's Avatar
There are two Furrion models. The std Forest River Backup Camera Model '12' has plenty of bad reviews. The available from Furrion as a direct purchase or swap out of the Model '12' is the much, much better Model '48' Observation camera. Both models look almost identical and use the exact same Forest River pre-wired mounting base. To swap out or install into that base that comes pre-installed at the back of your Forest River RV, TT or 5er is a simple matter of removing 4 easily accessible screws, unpluguing the electrical connector and then reversing that process with the uograded '48'. Furrion will cross ship to make it easy as possible. You will have a great camera and no need to remove and reseal where the bracket was. The '48' is wireless and its range is significantly greater than the '12'.
Maxxis 235/80/16E; AirBags w/AirLift 1 wireless compr; 4-Fold Tonneau; 6000# Dexters; mor/Ryde Rubber Pinbox & CRE3000 w/HD Wetbolts; Andersen UltimateII Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball; LCI Ground Control3 4pt+2pt Elec.Rear stabilizers; 3 Slidecovers; King Dishtailgater; 10ft. Portabote w/5hp Outboard; Dual A/C; Furrion48 Rearcam; Champion 3100 Inverter w/DIY Extended Run
hbillsmith is offline   Reply With Quote
Old 08-27-2015, 07:17 AM   #56
jeff64's Avatar
Recently purchased Rear View Safety RVS-83112 wireless system with magnetic mount. Will try out this weekend. So far , initial observations look favorable as far as range and absence of bluetooth interference. Previously tried out the i-Ball system which was not very good since you can't disable bluetooth on GM vehicles
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 08-31-2015, 06:36 AM   #57
jeff64's Avatar
RVS-83112 system worked quite well. Magnetic mount camera was quite versatile. Definitely would reccommend as a backup aid
14K Equalizer
Old 10-29-2015, 04:16 PM   #58
Just purchased a Surveyor 265rlds , backup camera prep only. What do we need to buy to make use of the prep only option?
uually is offline   Reply With Quote
Old 10-29-2015, 04:55 PM   #59
back up camera
don't bother with the camera. we have the 5th wheel surveyor that came with the camera and it is completely useless. it only points straight down shows the bumper and about one foot out from the bumper and will not adjust out to be usable
ValMelton is offline   Reply With Quote
Old 10-29-2015, 06:37 PM   #60
ElShamardo's Avatar
Camera
Yes, I am interested in purchasing the camera?
James & Kathi
back up camera
