Old 03-20-2019, 01:54 PM   #1
Angry Bad odor in bathroom - 29rsws 2019
I have a bad odor from the black water holding tank coming into my bathroom. Commode is clean. No water in floor. No odor outside or in any outside access doors. It seems to be coming from around the base of the commode but it is not loose. Any suggestions before I pull the commode.
H-Allen is offline   Reply With Quote
Old 03-20-2019, 02:11 PM   #2
fonzie's Avatar
Check your air admittance valve under sink if bad before pulling commode off. See thread below....
Odor from under bathroom sink
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 03-20-2019, 02:21 PM   #3
Just as confused as you
Scrapper's Avatar
First thing, check that there is water in the sink and shower/tub traps. Always use the drain stoppers for the sink and shower/tub drains, it will slow the evaporation of the water in the traps when you are not using the RV. Do you leave water in the toilet bowl at all times? Leave the toilet lid closed when not using the RV for extended periods, this will slow the evaporation of water from the bowl. If these are all good then follow fonzie's suggestions.
Richard & Jill
Camping since 1989, seasonal since 2000
The Faster I Go, The Behinder I Get.
Old 03-21-2019, 03:59 AM   #4
nomad297's Avatar
If it smells sort of like poop, check what was suggested above. If it smells like urine, possibly you have a Dometic 300 toilet that you need to replace.
Bruce
Old 03-21-2019, 12:57 PM   #5
Coachmen Clipper Fan
PFLOYD75's Avatar
Hi H-Allen...for what its worth, I went through a similar scenario and I recall seeing on here a product to use called "Happy Camper". Its a powder and ever since using this product (they honestly tell you on the package to only use one scoop and no more!), along with the usual dissolvable packet I drop into the black tank, I have had no further issues in this regard. This stuff really works! Check into it and let us know if you get it and if it works for you too!
Mark R. Wagner
PFLOYD75 is offline   Reply With Quote
Old 03-21-2019, 01:08 PM   #6
THAT'S IT! NO MORE TACO BELL!
breezyhillfarm is offline   Reply With Quote
Old 03-21-2019, 04:57 PM   #7
Urine smell
Bruce
I have noticed a urine smell. What is the problem with the toilet?? Thanks
pdqparalegal1 is offline   Reply With Quote
Old 03-21-2019, 08:26 PM   #8
When I smelled urine odor in the bathroom I first cleaned around the toilet then told my two boys to turn the light on before using the toilet at night.
Many RV toilets are too shallow and can cause more splash than a residential toilet. Over time all those little droplets build up and can cause a "public restroom smell". Better aim and frequent cleanings really help.
Sami. my Shih-Tsu "Co-Pilot" R.I.P
Politically Incorrect since 1943
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 03-21-2019, 10:36 PM   #9
HerveVR's Avatar
Had the urine smell problem last year.
After severe cleaning operations and many attemps to correct the situation, I decided to remove the toilet base.
I found the culprit: a cracked floor flange.
Replaced (beware, some are screw-type).
Problem solved.
2012 Lexington 265DS
HerveVR is offline   Reply With Quote
Old 03-22-2019, 02:16 AM   #10
CincyGus's Avatar
One cause I've heard of is if you have full hookups and you leave your gray tank open as some do, is that sewer gas from the dump tank can make it's way back up through your sink/shower/kitchen sink (whatever is connected to your gray tanks).
One solution to this is to let your sewer hose hit the ground between the connection and the hose support many use to create a downward U to act as a trap and which will hold water and prevent gases from backing into the trailer. Also stops those nasty sewer nats from finding their way into your camper.
Myself, I just leave both tank valves shut until I feel it's time to dump and eliminate the chance of that happening.
2015 GMC 2500K Denali, 2019 Forest River Wolfpack 23Pack15, 2014 EZGO Golf Cart
CincyGus is offline   Reply With Quote
bathroom, roo
