Old 05-25-2010, 10:06 AM   #11
tmmar's Avatar
May I ask, how did you determine that the sink was draining into the black tank? I find it very hard to see where the drains are going in my rig.
Tom and Margaret
2014 Berkshire 390bh-60
Old 05-25-2010, 10:12 AM   #12
First, be sure that both tanks are empty to start with. Otherwise this method could give you a nasty surprise. Then the way to tell which tank your sink or shower is connected to is to close both tanks and run water from the sink. Run a gallon or so into the tank. Then open one holding tank at a time. Whichever one the water comes out of is the tank the sink is connected to.
Hokiehall is offline   Reply With Quote
Old 05-25-2010, 10:19 AM   #13
tmmar's Avatar
I thought that the OP was able to see how his unit was plumbed. Kim, I didn't think of trying your method. Sounds like it would be pretty easy to determine where everything drains that way.
Tom and Margaret
Old 05-25-2010, 12:20 PM   #14
I'm not sure how he figured it out. He may be able to see how it is plumbed. I just figured I would give an easy solution so anyone can figure out where their water is going. It does help to know that.
Old 05-31-2010, 03:28 PM   #15
backin15's Avatar
I discovered the issure when I was sanitizing the water system. The sink in the bathroom moves the most water so I was using it to purge the air out of the hot water tank then to purge the bleach out of the water tank. After running the other faucets I pulled the drain valve for the grey tank and just got a trickle of water. I was worried that there was something plugging the opening so I checked the water level in the tank and it read empty. I checked the black tank and it registered full!
backin15 is offline   Reply With Quote
black tank, flagstaff
