Old 04-19-2016, 06:44 PM   #1
Battery Disconnect
Just bought a 2016 MicroLite 21FBRS and the literature says there is a battery disconnect as a standard feature;however, I can't find it?
Anyone know where it is located? It is not next to inverter or fuse panel.
Thanks!
Wvtroutman is offline   Reply With Quote
Old 04-19-2016, 07:53 PM   #2
aufinger's Avatar
On my 23LB, it's between the tongue jack and propane tanks. Look behind the tongue jack for a red on/off switch.
aufinger is offline   Reply With Quote
Old 04-19-2016, 08:06 PM   #3
Beneath the refrigerator near the floor; round chrome push/pull knob.
Papa GLS is offline   Reply With Quote
Old 04-19-2016, 08:08 PM   #4
Thanks. Its definitely not near the refrigerator. I never thought to look outside near the tongue jack. Will do so tomorrow. Thanks
Old 04-19-2016, 08:09 PM   #5
Must have relocated it; that's where it was on my 21fbrs.
Old 04-19-2016, 09:30 PM   #6
On my 832 IKBS it is under the Propane tanks, red key switch that you can turn. Complete disconnect.
HTH
SubVet is offline   Reply With Quote
Old 04-19-2016, 09:37 PM   #7
bikendan's Avatar
Rockwood/Flagstaff changed the switch locatoon, from inside to outside on the A-frame, for the 2016 model year.
Equalizer WDH
Old 04-20-2016, 01:50 PM   #8
Yep, it was behind the tongue Jack and slightly hidden by the propane tank cover.
Thanks for the help.
Old 04-21-2016, 10:05 AM   #9
Behind the propane tanks on my unit. Silver push/pull knob.
2017 Ram 1500 Sport 5.7
2015 Flagstaff 27VRL
Riccochet is offline   Reply With Quote
Old 05-09-2016, 08:07 AM   #10
Disconnect on a 2007 Flagstaff 8528 GTSS
I have spent the last 2 days hunting for a disconnect. I bought this unit used and do not have a manual for it. Everything works on shore power. New battery. No 12v power at panel. Can the owners manuals for older models be had anywhere? Would anyone have an idea if a disconnect exists for this model?
John
Jjmcardle is offline   Reply With Quote
Old 05-09-2016, 08:19 AM   #11
TURBS's Avatar
You may not have a battery disconnect.
Follow the positive battery cable off the battery, it should lead to a circuit breaker that may or ma not be resettable, and possibly your problem.
Old 05-09-2016, 08:21 AM   #12
TURBS's Avatar
Also it's going to be very tough to help you with your problems not knowing the year make and model of your unit.
Most of us put it in our signature line.
Old 05-09-2016, 08:27 AM   #13
Good idea, I did put it in the title of my post.
Old 05-25-2016, 10:34 AM   #14
Battery Disconnect Update
Took the battery into the coach and connected it directly to the panel terminals and powered all the 12v electrical lights/appliances successfully.
Toned out the positive and negative wires from the panel to battery connectors and could not produce a sound.
Would anyone know if the positive power line from the battery runs directly to the panel or would it make a stop at the breakaway switch? The wiring from the battery appears to go up from the battery and towards the front of the fifth wheel. I have yet to figure out how to access and trace the wiring further unfortunately.
Ford F250 7.3
Old 05-29-2016, 07:48 PM   #15
My 2109S has a breaker mounted to the left side frame rail under the camper toward the very front. There is a tiny button on it that you can push to reset it.
My camper also has a battery disconnect below the fridge to the right of the fuse panel.
2013 Rockwood 2109S
2010 Dodge Ram 1500 Crew Cab 4x4 Hemi
GearHd6 is offline   Reply With Quote
Old 06-01-2016, 07:37 AM   #16
That was exactly the solution. I had two switches actually. I think the one by the battery was good but the one by the pin was tripped for sure.
Thanks much!
battery, battery disconnect
