Old 10-01-2010, 01:46 PM   #11
steveqvs's Avatar
I agree with GeneT thats exactly what we do. Its amazing a little 5 watt solar plate can keep our 2 batteries topped off in the week we are not there.
Seasonal site camping
steveqvs is offline   Reply With Quote
Old 10-02-2010, 06:26 AM   #12
I have the same wing nut GeneT. I disconnected it a few weeks ago. Are the solar plates expensive? Can they be left on a battery over the winter to keep up the charge without doing damage? Thank you.
Virginia Camper
2010 831KRSS
2009 F150 King Ranch, 5.4L, 3.73
Blue Ox Sway Pro 1000
Virginia Camper is offline   Reply With Quote
Old 10-03-2010, 06:10 PM   #13
Gas Mans
We don't disconnect the battery...however with power tongue jack and stabilizers we turn the power off to those (so they won't get tampered with) by using the switch here...Im sure Harbour Freight has the same thing available...dont need to anything fancy for off / on task..
keyed battery master cut-off switch | Truck Electrical | Truck Accessories | Truck | Princess Auto
Gas Mans and Pat's Books
2010 Flagstaff 831FLSS
2010 F150 XLT 4X4
Gas Mans is offline   Reply With Quote
Old 10-04-2010, 04:09 AM   #14
Thanks Gas Mans. I pull the fuse for our tongue jack, but I could not find the stabilizer power source. Where is yours?
Virginia Camper
2010 831KRSS
Old 10-04-2010, 07:01 AM   #15
Also, the antenna booster switch that has a small push button and an indicator light will, in time run down the battery. Randy
Old 10-04-2010, 09:03 AM   #16
We simply keep it plugged in when at home to keep the battery charged.
2006 Flagstaff 831RLSS Travel Trailer
2007 Chevy 2500HD 'Classic' with the Duramax engine.
Converting a 1956 GMC PD4501 Scenicruiser, ex Greyhound into a motor home.
jackhartjr is offline   Reply With Quote
Old 10-04-2010, 09:31 AM   #17
Gas Mans
stabilizer power is from the main panel...on ours it's the last 12v fuse on the right bank of fuses. It's a pain to get to and run wires from becasue there is of course 110v and 12v in close proximity... We did the fuse thing for a while, but one trip I couldn't remember where I'd put it... had tons of spares, luckily!
2010 F150 XLT 4X4
battery, battery disconnect, flagstaff
