Old 09-09-2010, 10:35 AM   #1
Battery Disconnect
Hey Folks,
Does anyone know of a battery disconnect switch on Flagstaff TTs. We have a 2010 KRSS and our battery keeps draining. I think it is from the Carbon Monoxide detector. I cannot find a switch and I do not see one in the operators manual. I am getting ready to buy a disconnect switch to hopefully solve the problem. Any suggestions? Thanks.
Virginia Camper
2010 831KRSS
2009 F150 King Ranch, 5.4L, 3.73
Blue Ox Sway Pro 1000
Virginia Camper is offline   Reply With Quote
Old 09-09-2010, 11:17 AM   #2
NWJeeper's Avatar
Typically trailers don't have them. I don't know why but most of the TT and 5er owners here install disconnects themselves.
Ed & Wendy
www.nwjeepn.com
Old 09-09-2010, 11:25 AM   #3
milzat's Avatar
As NWJ stated, they don't come with a battery disconnect switch, unless you purchase a Ultra High End model Fifth Wheel.
Do a search here for "Battery Disconnect". You should fine a few post on the subject.
Mods for my Rockwood
http://www.forestriverforums.com/for...blem-6858.html
milzat is offline   Reply With Quote
Old 09-09-2010, 12:24 PM   #4
KyDan's Avatar
Many folks install their own and it's a pity the industry does not
include them in new RVs!!
Here is one that's got free shipping on Amazon--
Amazon.com: Guest 2110A Universal Mount Marine Battery Selector Switch with Alternator Field Disconnect (230 Continuous, 345 Momentary Amps): Sports & Outdoors
I have this one Amazon.com: 9003e e-Series Battery Switch Single Circuit ON/OFF: Sports & Outdoors
and they also have one for 1, 2 or both batteries for a few bucks
more.
Just search Amazon for battery switch.
And you are correct, if you don't disconnect the batteries they
will run down in a few weeks and that's bad for you and them.
Lead acid batteries do NOT like to be run down flat.
In fact, they will last the longest if kept fully charged.
I use a battery tender to do that.
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32
Old 09-09-2010, 01:47 PM   #5
http://www.forestriverforums.com/for...blem-6858.html[/QUOTE]
A little bit of a thread hijack...I was looking at the nice mod pictures, and I noticed something on the picture of the flag pole holder. I was told by the FR Rockwood warranty department that simply having the 2" hitch receiver bolted to your TT bumper voids your factory structural warranty. It doesn't matter what it is used for. In my case, I use one for a closeline. I was given major attitude when mine went to the factory for delam repairs. Just thought I would let folks know.
grandpaofthree is offline   Reply With Quote
Old 09-09-2010, 10:49 PM   #6
Thanks everyone. I will purchase a disconnect switch soon.
Virginia Camper
2010 831KRSS
Old 09-15-2010, 11:29 AM   #7
Where would be the best place to mount one of these?
rcase13 is offline   Reply With Quote
Old 09-15-2010, 03:23 PM   #8
I mounted mine on the A frame between the batterry box & the front of the TT.
2017 Chevrolet K2500HD, Husky W/D hitch
2009 Rockwood 2106 Mini-Lite
Nights camped 2010: 21
Nights camped 2011: 17
Nights camped 2012: 8
https://inlinethumb45.webshots.com/3...600x600Q85.jpg
revrnd is offline   Reply With Quote
Old 09-15-2010, 03:35 PM   #9
KyDan's Avatar
Some folks put them near the front of the RV near the batteries.
I put mine in the toe kick area down next to the floor right next
to my power center. It's a short run for the wires that way.
Some RVs have the LP gas detector wired directly to the battery.
If you have one of those, the switch needs to be at the battery.
NOTE-- I am NOT telling you to disconnect YOUR LP detector.
I know those things will run down your battery.
I know disconnecting the detector will save your battery.
If you disconnect yours, be SURE your LP tanks are off at any
time the gas detector is shut off.
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 10-01-2010, 12:38 PM   #10
We have a wingnut on one of the terminals ... part of my shutdown procedure is to spin the wingnut off & disconnect the battery.
My next act is to attach the "battery maintainer" solar cell to the now-isolated battery to keep it up.
GeneT is offline   Reply With Quote
Old 10-01-2010, 01:46 PM   #11
steveqvs's Avatar
I agree with GeneT thats exactly what we do. Its amazing a little 5 watt solar plate can keep our 2 batteries topped off in the week we are not there.
Seasonal site camping
steveqvs is offline   Reply With Quote
Old 10-02-2010, 06:26 AM   #12
I have the same wing nut GeneT. I disconnected it a few weeks ago. Are the solar plates expensive? Can they be left on a battery over the winter to keep up the charge without doing damage? Thank you.
Virginia Camper
2010 831KRSS
Old 10-03-2010, 06:10 PM   #13
Gas Mans
We don't disconnect the battery...however with power tongue jack and stabilizers we turn the power off to those (so they won't get tampered with) by using the switch here...Im sure Harbour Freight has the same thing available...dont need to anything fancy for off / on task..
keyed battery master cut-off switch | Truck Electrical | Truck Accessories | Truck | Princess Auto
Gas Mans and Pat's Books
2010 Flagstaff 831FLSS
2010 F150 XLT 4X4
Gas Mans is offline   Reply With Quote
Old 10-04-2010, 04:09 AM   #14
Thanks Gas Mans. I pull the fuse for our tongue jack, but I could not find the stabilizer power source. Where is yours?
Virginia Camper
2010 831KRSS
Old 10-04-2010, 07:01 AM   #15
Also, the antenna booster switch that has a small push button and an indicator light will, in time run down the battery. Randy
Old 10-04-2010, 09:03 AM   #16
We simply keep it plugged in when at home to keep the battery charged.
2018 Flagstaff 832IKBS Travel Trailer.
2015 Silverado High Country.
jackhartjr is offline   Reply With Quote
Old 10-04-2010, 09:31 AM   #17
Gas Mans
stabilizer power is from the main panel...on ours it's the last 12v fuse on the right bank of fuses. It's a pain to get to and run wires from becasue there is of course 110v and 12v in close proximity... We did the fuse thing for a while, but one trip I couldn't remember where I'd put it... had tons of spares, luckily!
2010 F150 XLT 4X4
battery, battery disconnect, flagstaff
