Old 06-15-2017, 10:07 AM   #1
Novice Travel Trailer Guy
benchmarks's Avatar
Battery Disconnect Switch - 2018 Microlyte 25BRDS
I have the Microlyte 25BRDS. When trailer not in use should the battery disconnect switch be on or off? When plugged in should it be on or off? Thanks.
2018 Flagstaff Micro Lite 25BRDS Travel Trailer
2018 Chevrolet Silverado 2500 LTZ
benchmarks is offline   Reply With Quote
Old 06-15-2017, 10:27 AM   #2
BooBoo23's Avatar
Read about the use here: http://goneoutdoors.com/use-disconne...r-8720625.html
2014 Palomino Puma 25RS
2011 F-150 Super Crew XLT
Days camped in 2014 - 23 Camped 2015-47
Camped 2016-71, 2017-33, 2018-29 booked
KT4W
BooBoo23 is offline   Reply With Quote
Old 06-16-2017, 07:06 AM   #3
GulfHusker's Avatar
Take it from recent experience, turn the disconnect off when not in use. In my Flagstaff, that means the key comes completely out. I had mistakenly left it engaged and it ran the battery to below 3volts, barely light an LED bulb. We were just heading out to a campground and had to stop and buy another battery. Advanced Auto Parts was kind enough to keep the drained one, which had only been used once, over the weekend to charge it and test it. It wound up being fine, but now I have 2 batteries, one is always ready, hooked up to a Battery Minder, in case I pull the same mistake again.
Otherwise, you leave the battery switch in the on position when plugged in.
GulfHusker is offline   Reply With Quote
battery, battery disconnect, switch
