Old 06-18-2012, 08:45 AM   #1
Swamp Camper
battery Help needed (Solved)
My 2005 Flagstaff 5th wheels battery is charged but it wont send any power to unit. Need help.
jasper is offline   Reply With Quote
Old 06-18-2012, 09:01 AM   #2
Battery disconnect off?
Also check the breakers near the battery. Sounds like one of them might have tripped. They are resettable. there is a very small button on the bottom of each one. Be sure they are all in.
Old 06-18-2012, 09:11 AM   #3
Swamp Camper
The only breakers I know of are in the main control panel and they are all reset. This happened when my pigtail (Tow plug) sparked when i unplugged it and to put it out of the way to store it and it rubbed on a metal bolt (SPARKED). Are there fuses between the battery and the main box? Everything works with the shore power.
Old 06-18-2012, 09:31 AM   #4
Trace the positive battery cable from the battery, and you will find one or more, small, resettable breakers, as mentioned in post #2. If you saw a spark, you created a situation, that would have tripped one of those breakers. You need to fix that pigtail, or at least get some tape on it. You should never have a bare wire around electricity.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 06-18-2012, 11:23 AM   #5
Swamp Camper
Thanks for all the help..ill take the advice and look for those resetable breakers....much appreciated
Old 06-18-2012, 11:56 AM   #6
Swamp Camper
Looked for resettable breakers...traced the positive cable to what looks like a relay ..... this leads to a 30amp Auto type Fuse. Ill try to change the fuse. I have a 2005 Forest River Flaggstaff 5th Wheel. Would that have fuses instead of a breaker leading from battery??? Could I have blown a fuse at the main breaker Panel? Panel has (2) 40 amp and (10) 15 amp fuses in the main panel. My shore line runs RV interior lights also tested and my Tow vehicle and it runs my interior lights. The only thing that doesn’t run anything is my battery. It has a charge of 12.94 on it, but wont run anything.
Old 06-18-2012, 03:44 PM   #7
What looks like a relay is the breaker. Feel along the bottom. You will find a very small button. Push it in. Get a volt meter and start tracing power.
Old 06-18-2012, 05:11 PM   #8
Herk7769's Avatar
The do-hickey you are looking for may have a red rubber cover on it.
It looks like:
HAM CALLSIGN - KC3FFW
Old 06-18-2012, 05:24 PM   #9
TURBS's Avatar
If u do find it and it's tripped imo I would replace it with a self resetting circuit breaker of the same amps.
Old 06-19-2012, 07:27 AM   #10
Swamp Camper
Thanks to everybody that helped me out. I could not tell the difference between a breaker and a relay (feel really stupid) .....I reset it and every thing is working!!!!!!!!!! Thanks again
2007 F250 diesel 6.0l
Old 06-19-2012, 07:59 AM   #11
MotocrossCamper's Avatar
No need to feel stupid, I won't tell you how long it took me to realize the ground fault in the bathroom controlled all the other outlets in the camper! If it wasn't for this sight I would still be looking!
MotocrossCamper is offline   Reply With Quote
Old 06-19-2012, 09:55 AM   #12
LOL. This happened in my trailer and my wife thought something was badly wrong with our electrical system. I went into the bathroom and reset the GFI plug and all was back to normal. If it wasn't for this and similar sites on the internet, I'm sure I would have been phoning the dealer.
2011 F150 SuperCrew 5.0 4x4
2012 Flagstaff 27BESS
pappcam is offline   Reply With Quote
battery, led pad
