Old 06-19-2016, 08:29 PM   #1
Battery Powered Tongue Jack not working
I apologize if there is already a thread on this, but when we picked up our Microlite 25 DS and were going to raise the hitch to attach to the truck, it didn't work when we turned the switch on. Then again it did work for a few minutes and since then we have had to handcrank up-and-down this weekend. Hubby checked the battery inside the camper and it says fully charged. Is there a way to determine if this is a battery issue versus something else before we take it to a dealer for repair? Thanks much. The battery was on the camper all winter but inside storage just FYI. Thanks much!
PTLady is offline   Reply With Quote
Old 06-21-2016, 04:54 PM   #2
Head Rambler
Do all the other 12 volt items in the RV work?
Do you have a battery disconnect switch? Is it turned on?
Have you looked near the front of the unit for a fuse inline with the jack power?
Do you have a multimeter? If so do you know how to check voltage with it?
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 06-21-2016, 05:23 PM   #3
bikendan's Avatar
You're talking about an electric jack.
a hitch is what connects the trailer's A-frame to your truck's hitch receiver.
Most likely it blew the inline fuse, as Bama said.
Equalizer WDH
Old 06-21-2016, 05:35 PM   #4
dcheatwood's Avatar
Yes, there should be a fuse between the battery and the jack.
2018 Forester 3011 DS
Old 06-21-2016, 09:46 PM   #5
aufinger's Avatar
Also, tighten up the bolts holding the jack to the frame. It may have a bad ground connection. Larry G.
2016 Toyota Tundra 5.7L DC
2016 Flagstaff Micro Lite 23LB
USMC (Retired) 70-91
aufinger is offline   Reply With Quote
Old 06-22-2016, 07:03 AM   #6
Head Rambler
I'd check the mounting bolt tightness, but if the light comes on, on the jack then you may have a bad motor or switch.
If it's still under warranty, it may be time to contact the dealer. If it's not, then it may be time for a new jack.
Gotta go campin!
Old 06-22-2016, 12:21 PM   #7
MartiB's Avatar
I had a similar issue with my Salem CruiseLite last summer. In 95 degree weather I had to hand crank. I was back at my storage place fortunately. When they checked it out, it was a couple of loose wires which were repaired. Not sure what wires or where but I'd check the jack for any loose wiring.
MartiB is offline   Reply With Quote
Old 06-22-2016, 12:26 PM   #8
We had that problem.... twas a bit of rust/corrosion on the connection to the battery. Cleaned that... smooth sailing.
Joe & Sue - Camp Mutt Dazey
2008 Flagstaff Super Lite 26RKS
2008 Ford F-150
hotzfamily is offline   Reply With Quote
Old 06-22-2016, 12:30 PM   #9
Loose Wires
Hate to suggest it but I think the FS employs 80 year old grandmothers to crimp wires with manual tools. Nothing like having a wire fall out of a crimp connector at the site. Like the American Express commercial, never leave home without it (tools, that is).
Russ
RussPastuch is offline   Reply With Quote
Old 06-22-2016, 02:16 PM   #10
Newbie Level 2
Tongue Jack Fuse
My 2015 Microlite had same issue. Found and INLINE 30 AMP Fuse, follow red wire from the jack back along the aframe of the trailer, mine was near the battery , left side. My 18v battery screwgun also worked when the manual cranking was needed.
KeepTravelin is offline   Reply With Quote
Old 06-22-2016, 02:19 PM   #11
Had similar issue with mine. Turned out to be a loose battery cable connection. Tightened and worked like a charm.
Dwayne and Susan
Jiro and Phoebe-4 legged family members
Mike and Dana - Traveling buddies
2016 Ford F350 XLT 6.7 Powerstroke DRW 4X4
2016 Brookstone 395RL
dwayneb236 is offline   Reply With Quote
Old 06-23-2016, 09:18 PM   #12
kittlecat's Avatar
Electric tongue jack troubles
I had a TT with an electric tongue jack that started working intermittently. Turned out moisture had gotten inside where the fuse was housed near the battery (on my unit) and was causing the tongue jack to malfunction. I sprayed WD40 on the end of the fuse and reinserted it and that took care of the problem.
kittlecat is offline   Reply With Quote
battery, hitch, power
