Old 07-12-2017, 08:55 PM   #1
Battery selector switch & solar
I have 2 - 100 watt Renogy panels I mounted on the roof of an RV with a 30 amp Wanderer controller.
I have the panels connected as shown on the diagram attached. I am using a 125 Ah AGM battery. I want to add 2 flooded lead acid dual purpose 12v batteries, wired in parallel, via a battery selector switch. (B1, both, B2, off) I am aware I will have to change battery type depending on which bank is selected (never both) Am I able to configure this selector switch and old batteries into system? Any help appreciated. Click image for larger version
Name:	rv 19sb solar diagram.jpg
Joe_L is offline   Reply With Quote
battery, select, solar, switch
