Old 09-27-2019, 01:34 PM   #1
Bedroom tv won't work on antenna
I have a 2020 32ft Flagstaff 5th wheel superlight.
It has 2 TV,s I can't get the one in the bed room to work on the air antenna
What am I doing wrong?
Ke-Mo-Sah-Bee is offline   Reply With Quote
Old 09-27-2019, 03:27 PM   #2
Some models have a satellite connection AND an antenna connection in the bedroom. Mine does. Are you sure you are connected to the proper coax connector? Are you sure they are labeled properly?
Does the main tv work OK on antenna?
Days Camped: '16=46 '17=30 '18=51 '19=50
Old 09-30-2019, 08:12 AM   #3
The TV started working 2 nights ago and I have no Idea why but it fixed its self I guess.
Old 09-30-2019, 08:20 AM   #4
What did you change?
Did you reconnect or rescan?
Things typically just don't fix themselves.
