Old 07-19-2017, 01:12 PM   #1
Kasual Kamper
Bin recommendations needed for understorage
We have a MicroLite 21DS. The large passthrough underneath is nice, but reaching stuff in the middle might be a challenge.
Has anyone found storage bins that are sturdy enough to take some abuse that are low and long enough to work perfectly in that space? The slide out shelf is a nice idea, but very pricey.
JayArras is offline   Reply With Quote
Old 07-19-2017, 01:33 PM   #2
Semperfi24's Avatar
We use storage containers (I'll call them Rubbermaid), designed for under the bed storage. We use 4 of them. On each side of the trailer we have one on top of the other. Just put the commonly used items in the top bins, because the only way to access the bottom bins is to take the top one out first, or push the top bin toward the center to get the bottom lid opened enough.
*Note. Not sure the opening size for your trailer compartments, on our Mini light, these bins cant be removed from the "door" or "passenger" side. That opening is taller, but narrower and the bins are too wide. So all of the bins have to come out on the "drivers" side of the trailer (that opening is short but wide).
_________________________
2018 Rockwood Mini Lite 2504S
2019 Ford F250 Lariat FX4 6.7 Powerstroke
Semperfi24 is offline   Reply With Quote
Old 07-19-2017, 01:40 PM   #3
Location: Minnesota ( wishing we were boondocking in the New York Catskills )
Milk Crates work real nice, and have all those openings in the sides. You can use a stick to push them inwards, and a hook on the end of the stick, or a rope, to pull them out. Simple but works .....
Jeff and Abby
Fur Babies - Xandra Sophia (GSD) and Neo (Min-Pin Mutt who thinks he is a cat)
2015 Tracer Air 235 (previous 1994 Veri-Lite 1130 TC)
1998 Dodge Ram 2500 Quad Cab - 360 - 46RE (Built)
Jeff_and_Abby is offline   Reply With Quote
Old 07-19-2017, 01:57 PM   #4
Head Rambler
I've built my own pass-thru drawer for the last three RV's we've owned. Makes it a lot easier to access the center of the pass-thru.
Here's what I built, but it could be customized to fit any size pass-thru.
Gotta go campin!
Old 07-19-2017, 02:04 PM   #5
Kasual Kamper
That's real nice! I like that! What did you use for materials?
Old 07-19-2017, 02:05 PM   #6
Herowe's Avatar
I bought cheap laundry baskets from the Dollar store. Hook them or just lean in to pull them out from center.
One holds setup tools and supplys. One holds fresh water and cable hook ups. One holds dump station supplys. One holds other misc tools and equipment.
Will probably upgrade to covered underbed style storage bins later. As we get more organized and settled into the new trailer, I can look for specific sizes needed.
Happy Camping.
Henry & Cindy
2017 F-350 4X4 Crew Cab Lariat 6.7L Diesel 3.55 Elec Locker Rear
2017 Rockwood Ultra Lite 2902WS
Herowe is offline   Reply With Quote
Old 07-19-2017, 02:07 PM   #7
Kasual Kamper
I haven't looked at the Rubbermaid ones, but the ones they sell at Bed, Bath and Beyond would never stand up to trailer use. I like the concept, though.
Old 07-19-2017, 04:13 PM   #8
Head Rambler
Here's the drawings for the last couple that I've made.
Here a link to a little different design.
Pass-thru drawer plans.
Gotta go campin!
Old 07-19-2017, 06:39 PM   #9
Kasual Kamper
That's awesome! Thanks for sharing! One question though... where do you get plastic garage door rollers? All that I've ever seen are metal with ball bearings inside.
Old 07-21-2017, 07:17 AM   #10
We use clear plastic storage containers so you can see what's in them. Also use a couple of plastic dish pans for citronella candles, newspapers for the fire, bungies, etc. Would use milk crates but small trailer, small opening. Always keep the tools just inside the opening.
stellaandspike is offline   Reply With Quote
Old 07-21-2017, 07:31 AM   #11
Herk7769's Avatar
Amazon, where else?
https://www.amazon.com/dp/B016VNU14E...a-324894558848
HAM CALLSIGN - KC3FFW
Old 07-21-2017, 07:35 AM   #12
Kasual Kamper
Good idea, except in my experience, the plastic is rather thin and won't take the abuse. Thanks for the tips!
Old 07-21-2017, 07:39 AM   #13
Kasual Kamper
Originally Posted by Herk7769 View Post
Amazon, where else?
Old 07-21-2017, 07:49 AM   #14
OP, Do you have the Murphy bed option? If so (I do), the pass through is easily accessed under the sofa. If not, does the mattress pivot up for storage access? And, if the mattress does pivot up, is the pass through storage accessible or is it walled off from the under bed access? I'm not familiar with the non-Murphy bed construction so thank you for educating me if yours is the standard queen. Otherwise, the storage under the sofa is very accessible.
2016 Microlite 21DS
2014 Ram 1500 QC 6 cyl. 8 spd.
Blue Ox SwayPro
windsurfdog is offline   Reply With Quote
Old 07-21-2017, 08:10 AM   #15
Kasual Kamper
I do not have the Murphy bed option. In my configuration, under the standard queen bed are three drawers and a space behind that for some things that would be accessed less frequently by lifting the bed. The pass-through is behind that, but is totally enclosed and not accessible from the inside.
Old 07-21-2017, 08:17 AM   #16
Gotcha. The Murphy bed does eat a bit of the pass through space but the under sofa accessibility helps make up for space lost.
Good luck with your bin search! And I hope you enjoy your 21DS as much as we are enjoying ours!
2016 Microlite 21DS
Blue Ox SwayPro
storage
