Old 10-11-2011, 04:54 PM   #1
Black and Gray tanks
We have a 2012 Flagstaff 26rlss. Have been out 6 days this last month. My question is after only 2 days the Black and Gray tanks are 2/3 full. I can see the gray but not the Black tank.Its just 2 of usWe take 4 showers and the sink water...The Black shouldnt be 2/3 full after 2 days !!!!????
Any ideas???
gene2661 is offline   Reply With Quote
Old 10-11-2011, 05:19 PM   #2
I have found that I can not trust the guages. The DW and I get about 3 days on the black tank on our 26RLS. Our shower is connected to the black tank. Only once has the tank filled to where the shower water started not to drain (my indicator the tank is full). If we are going to camp for more than 2 nights without sewer hookups I bring the 18 gal blue tank. I have had the blue tank for over a year and used it the first time this past weekend (didn't really need to, but it made me feel better). Herk put a post up a few months ago about some real good sensors and information on how they work, you might try to search out that info.
Kirk, KN1B
2013 Cardinal 3800FL
2009 GMC 3500HD CC LB SRW
kbrown1075 is offline   Reply With Quote
Old 10-11-2011, 06:47 PM   #3
Thanks for getting back...But I thought that the shower was GW and not BW. If so then the GW shouldnt fill up in 2 days
Old 10-11-2011, 06:48 PM   #4
The GW and BW are both 38 gal tanks
Old 10-11-2011, 07:20 PM   #5
(Kim)
Labzy's Avatar
If you look from underneath the trailer at the tanks, you can usually see how full they really are.
How long of showers are you taking? Try closing the tub drain so after your shower is done you can see how much water you used.
Many people on here use the Oxygenics shower nozzle which uses less water.
2010 Dodge Ram 1500
2012 Rockwood 2306
Kim
DH (Alan), DD (Madison) and Zoey the lab,
Labzy is offline   Reply With Quote
Old 10-11-2011, 07:59 PM   #6
Black and grey tanks.
We also turn off shower head while lathering up and washing hair. Saves water. Also if toilet paper is dropped in tank it can cause sensors to give wrong reading.
murry1946 is offline   Reply With Quote
Old 10-11-2011, 09:07 PM   #7
Triguy's Avatar
Generally, the shower and sinks are gray water and the toilet are black. Maybe there is something about the unit you have that pipes the gray into the black.
As for the tank monitors, the lights for the BW are notoriously incorrect, as mentioned. Toilet paper and other "stuff" messes with the sensors. Best to look down your toilet or look at the tanks outside to see how full it is.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 10-11-2011, 09:17 PM   #8
ken0042's Avatar
I went so far as to fill my tanks with 5 gallons of water at a time; using a Home Depot bucket. I did this at home so I could see what the capacities of my tanks were. Link What I found was that my grey read 2/3 full when it was actually 1/2 full, and full when it was really 2/3 full.
Wolf Pup T16P owner
"The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine." - Abraham Lincoln
ken0042 is offline   Reply With Quote
Old 10-12-2011, 04:54 AM   #9
In our 26RLS the shower is plumbed to the black tank. This is fine with me as this puts more water into the black tank making cleaning the tank much easier. Most people seem to prefer the shower to the gray tank. I have read where some people have had their plumbing changed to the shower to the gray tank. I like ours just the way it is!
Kirk, KN1B
Old 10-12-2011, 07:20 AM   #10
camper007's Avatar
I've never heard of the shower going to the black tank. Where the toilet valve close's, no fume's can get in the trailer, but the shower drain is a different story, it doesn't close.
camper007 is offline   Reply With Quote
Old 10-12-2011, 07:49 AM   #11
The sensors are garbage as they foul up all the time. Black tank if you can't look direct into it, will usually bubble just before it is completely full. You will notice an air bubble coming up when you flush it. If this happens you need to dump. Gray water fills fast especially if you shower and wash dishes. My gray water tank in the kitchen will fill within 2 to 3 days. When hooked up to sewer I leave the gray valves open.
murph164 is offline   Reply With Quote
Old 10-13-2011, 04:53 AM   #12
There is a trap in the shower drain preventing the fumes back into the TT, just like your shower at home. Have NEVER had a problem with oder. Makes emptying the black tank easy as there is plenty of water to move out the solids.
Kirk, KN1B
Old 10-13-2011, 07:22 AM   #13
Curious about your shower draining into your black. You sure? I would think this would be a no-no. If you ever overfill your black you will end up with quite a nasty surprise in your shower. Is there some kind of one way valve to prevent this?
Len & Cheri is offline   Reply With Quote
Old 10-13-2011, 01:30 PM   #14
ken0042's Avatar
They make them for home plumbing; I installed one when I put in the plumbing for my basement washroom. I would think something similar could be installed between the trap and the black tank.
Wolf Pup T16P owner
Old 10-13-2011, 05:13 PM   #15
Sure, but did FR install that in his unit or did he? I've never heard of a unit coming from the factory like that. Makes me curious if FR has that as an option now or what the story is. There was a thread not to long ago that talked about doing something along like that and it was discussed how it would be nice if we had that option.
Old 10-13-2011, 07:18 PM   #16
we are going tomorrow to pick up our first camper,,it is an 2008 Maverick Palomino 9ft. just saw it bw and gw tanks are about 7 gals,,,having had a 34 rv with 50 gal tanks,,,how do campers deal with 7 gal tanks,,,,
emcr703 is offline   Reply With Quote
Old 10-14-2011, 04:57 AM   #17
Yep, I'm sure. I have full hookups next to the house where we keep the TT. I emptied and cleaned both the gray and the black tanks. Dumped 5 Gallons of water down the drain in the shower. Opened the black tank valve, and watched through my clear 45 deg adapter. About 5 gal of water came out. I opened the gray valve... no water. As far as when it fills up; this has only happened once while I was taking a shower. The water just stops going down the drain. We were hooked to sewer so I dumped. I don't know about a check valve on the shower drain. Like I said earlier in this thread, I like the shower going to the black tank, more water with the solids, better tank cleaning.
Kirk, KN1B
Old 10-14-2011, 10:29 AM   #18
ken0042's Avatar
I agree- I would like that as well. But like LFugate I am curious; did your trailer come like that from the factory, or was it something you installed yourself?
Wolf Pup T16P owner
Old 10-14-2011, 04:58 PM   #19
The TT came like that.
Kirk, KN1B
Old 10-16-2011, 10:39 PM   #20
biken201's Avatar
We just picked up our new 2012 Roo HTT, and our shower drains to the black tank. We were told it helps to keep fluids in the tank and to empty the solids when draining.
11' Dodge Ram 3500 DRW 6.7 Cummins
12' Rockwood Roo 233S
Current: AZ
Wife: NY
Me: IL
3 Akitas (RIP D-Dog)
biken201 is offline   Reply With Quote
