05-23-2014, 01:42 PM
Black tank
Just purchased a 2014 flagstaff with a black tank flush on the outside. Did you need to put a pressure regulator on or can you hook up to city water pressure?
05-23-2014, 01:46 PM
I guess you should, but I have never did it. I aways just hook it up direct for atleast 75 flushes and no problem yet....but I do use one on the the city water inlet all the time... I guess I should also add that is a direct line made out of the samething your hose is made out of.
Coachmen M/H
Concord
2018 / 300 DSC
05-23-2014, 01:54 PM
I do not use my water regulator when using my black tank flush.
2015 Chevy 3500HD
2013 Sandpiper 365SAQ
05-23-2014, 02:01 PM
Ret E-9 Anchor-clanker
Most RV Parks are lower pressure than what the city supplies to your house (If you have one/or visiting someone). I've never seen a pressure reducer installed at any flush stations. I have never used one at the flush station.
05-23-2014, 02:21 PM
The black tank rinser is just a pipe with a spray at the end and doesn't really need to hold pressure so there's no need to put a pressure regulator on it. Less pressure would make it less useful anyway.
05-23-2014, 03:17 PM
Totally agree. In this case more is better.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
05-23-2014, 03:52 PM
Always Learning
While it's probably not a bad idea to put it behind the regulator, I like having full pressure to my black tank flush.
05-23-2014, 05:43 PM
Same here.
05-23-2014, 06:13 PM
Me too. No pressure reducer when back flushing.
Chuck and Joanne
2014 Flagstaff Super Lite Classic 27RLWS Emerald
2013 Dodge 2500 4x4 Laramie Crew
Equal-i-zer 1200/12,000 4-point WDH
05-24-2014, 12:04 PM
I was told by our dealer to use the regulator when flushing out black tank. Not sure if it matters.
Tommy and Wanda
2014 Flagstaff 27RLWS
2020 Ford F-150
Equal-i-zer 1,200/12,000 Weight Distribution w/ 4-Point Sway Control
05-24-2014, 12:14 PM
Pressure reglator
I don't use one and I don't turn the water on full force. I can hear mine so I get some sort of hint. I worry that you could still cause damage if pressure was so great that the sprayer could not relieve it.
2013 Ford F-350 SD Diesel, 4X4, Crew Cab, Lariat
Sabre 2014 32RCTS, Pullrite Superglide 2900 18K
05-27-2014, 12:13 AM
Cat1956 I was told the same thing from my dealer. They said to protect the connections on the plumbing that whenever we are hooked to with the hose then use the regulator.
05-27-2014, 05:15 AM
You should buy two if you do that. I would hate to use anything on the flush line and then put potable water through it... <ick>
06-27-2014, 06:54 PM
You still have the pressure but reduced volume when throttling the supply valve. On some models the black flush hose is up in the wall of the bath to a back flush preventer. If a hose lets go there it's no bueño.
Brenda and John
Master Blaster of the Navy
06-28-2014, 08:16 AM
You should have a back flow preventer in that line. By the way you have a constant pressure. For someone to say it can come back up into your hose please let me know how? you hook the hose to the fitting and turn it on the tank valve is open how will you get back pressure? Just because the label say's black tank flush people are just Pernod.
Coachmen M/H
Concord
2018 / 300 DSC
09-03-2014, 09:15 AM
I have a 2012 Flagstaff with black tank flush connection, is this just a spray nozzle or is it like the tornado nozzle I have seen advertised. How effective is it?
Hobie Kayaks
2008 F-250 Spartan Tuner
2012 Flagstaff
09-03-2014, 12:29 PM
No pressure regulator required
09-03-2014, 12:59 PM
Don't really know, but I have a clear extension and you would be surprised at the TP and solids that still will come out after 15 or so minutes using it. After I see clear water then all of sudden I see chunks coming out. I do it every time I'm hooked to a sewer and will run it atleast 30 min. before I head for home..... ....
Coachmen M/H
Concord
2018 / 300 DSC
