Old 02-26-2012, 03:09 PM   #1
Capsfloyd's Avatar
Smile blocking on double axle trailer
for side to side level, if using 1 x 10 do you need to have 1 long enough to support both tires . I have one that is a few inches short, could I make 2 pieces of support for each tire.
I also have the lynx system too.
Thanks,
Capsfloyd is offline   Reply With Quote
Old 02-26-2012, 07:08 PM   #2
TURBS's Avatar
I use 2x10
A 1x may not hold up may split in the middle.
Also longer is better short ones tend to slip out or move.
Old 02-26-2012, 08:13 PM   #3
Capsfloyd's Avatar
Originally Posted by f1100turbo
I use 2x10
Thanks , I have some 2 x 10's
2009 Rambox crew cab
2012 831 Flagstaff RKSS
2010 jeep Liberty
2010 Harley Davidson Ultra Classic
Old 02-26-2012, 08:22 PM   #4
TURBS's Avatar
your welcome .
fyi take a 4x4 and angle cut the ends till they fit between the two tires instead of throwing sticks of wood between them . works great !
Old 02-26-2012, 08:59 PM   #5
LKicklight's Avatar
Blocks
Might want to try the X-chock..bought them for our RV..they work great and are very easy to use and look better that wood chocks...you will like them...
LKicklight
Crusader 270 RET
2500 HD LT
LKicklight is offline   Reply With Quote
Old 02-26-2012, 09:37 PM   #6
I LOVE my x chocks! Make the trailer 100 times more stable than regular chocks.
As for blocking, I guess you are referring to raising one side to level the trailer? A couple of 2xs and a couple 1xs should do the trick on just about any place.
2010 Cherokee Grey Wolf 28BH
86ish palomino slide in
2000 F250 superduty 4x4 7.3/6speed crew/ short
edman87k5 is offline   Reply With Quote
Old 02-27-2012, 10:47 AM   #7
Capsfloyd's Avatar
I was asking about leveling side to side. I'll look into the x chocks In between the tires. Front to back is the tongue jack .
Thanks for the replies
2010 jeep Liberty
axle
