Old 04-25-2016, 12:43 PM   #11
MilCop4523's Avatar
I had some LVL beam material left over. dense material less compression. and it happens to be painted yellow so i can't forget it in the green grass.
09 Sundance 31.5 XLT Bunkhouse
17 Greywolf 22rr Toy Hauler
and
The new toy hauler - 2016 Ford F150 Supercrew XTR ECOBOOST.
MilCop4523 is offline   Reply With Quote
Old 04-25-2016, 01:10 PM   #12
Originally Posted by Big bird View Post
I see others using the plastic pads and they deteriorate rapidly.
My blocks are close to 15 years old and still look great. I've never seen any deterioration of them.
Iwritecode is offline   Reply With Quote
Old 04-25-2016, 01:18 PM   #13
MilCop4523's Avatar
we use teh lynx levelers as well and have since 2011. we crushed one but thats it.
and
Old 04-25-2016, 04:33 PM   #14
trbomax's Avatar
2x12 fits perfectly in a milk crate.Cut the 12" long and you can get 10 of them in there standing on end.
trbomax is offline   Reply With Quote
Old 04-25-2016, 04:57 PM   #15
Will only use blocks if stab jacks won't reach the ground. So far, it's never happened in 50+ yrs of camping. I carry Lynx blocks in the bed of the truck but have never used them.
Old 04-25-2016, 06:50 PM   #16
Blocks will add stability broadening the base imprint . A note on using blocks under front jacks, ALWAYS put the blocks down to run the same as the trailer. I see too many people knock the trailer off the blocks when backing in to hook up or lock in their fifth wheel by putting the block cross way to the trailer.
hillsdaletc is offline   Reply With Quote
Old 04-25-2016, 06:58 PM   #17
That is exactly why I leave the Bal X Chocks on until I get hitched. They are the first thing installed and the very last thing removed and stowed and only after the parking brake is engaged and the transmission is in park.
Old 04-26-2016, 08:48 AM   #18
beagle22b07's Avatar
Stability of stab jacks
I recently read a post here that stated that the jacks were in their most stable position when extended over 12". This changed my thoughts on using blocking as I used them so I wouldn't have to crank as far. Since then I've got a bit for my cordless drill and use blocking sparingly.
Larry & Chris (Abbey & Brody camping cats)
2016 Ford F-150 XLT Sport, Super Cab, 3.5 EcoBoost, 3.55, 4x4, MaxTow w/36 gal fuel tank
2015 Rockwood MiniLite 2104S, EMS-30HW, Carchet TPMS
Days Camped: 2015 = 51; 2016 = 59; 2017 = 20
If you're lucky enough to be camping......You're lucky enough.
beagle22b07 is offline   Reply With Quote
Old 04-26-2016, 09:10 AM   #19
Pickin' & Campin'
This depends on the design of the jack/stabilizer.
Typical 'scissor' jacks are the most stable when the two upper arms and the two lower arms are extended far enough to form a square.
Stabilizer jacks (electric and manual) are the most stable when the cross arm (sometimes painted yellow/sometimes black) extends to the point where it forms a right angle with the ground contact leg.
Front landing gear/jacks on 5th wheels are most stable retracted, using the inner leg as the needed extension.
Sturdy blocking to get what is described for any of the above, will not affect stability.
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 04-26-2016, 10:22 AM   #20
Pickin' & Campin'
I had a PM to explain what I meant by the stab jacks forming a 90º right angle.
Here's a drawing I hope helps.
stabilizers, lock
