Old 05-25-2016, 08:19 PM   #1
brake shoes, and nipples
hi all , first post , am visiting canada and using my father in laws 5th wheel (8524 ress) , i have a question about the brakes , whose brakes are they ? ie what manufacture? ... like is there a generic hub used ? also there appears to be no grease nipple (zerk fitting) this camper came with no instruction manual , they bought it in 2007 , it is a 2005 camper ... is there a maintenence schedule for these things , ie , repack wheel grease , or replace brake shoes .etc .... i will search the forum as best as i can ...
cheers for any help ..
kiwi is offline   Reply With Quote
Old 05-25-2016, 08:45 PM   #2
Flybob's Avatar
The zerk fitting is for ez-lube type bearings. In these wheel bearing grease is injected via the zerk and travels to the back of the hub then back through the bearings to lube them. There are those that use these and those that do not ( I will not take sides here). If you have no history of regular maintenance and you are concerned about shoe wear, I suggest pulling the wheels checking /replacing the shoes and checking/repacking bearings the old fashioned way.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 05-25-2016, 08:56 PM   #3
cheers i see the brakes are AL KO , and after a little googling have found the right size , so at least i have a parts breakdown of the hub and brake components , is hayes or alko more readily available in saskatchewan , ? who do i order the primary or secondary shoes(linings ) from ? , i think it would benifit from a repack of grease in the wheel bearings , ... thanks for your help .
brakes
