Old 09-30-2017, 01:20 PM   #1
mikdor1's Avatar
Broken battery disconnect switch...
Well I broke my battery disconnect switch. On the switch casing it says 75 AMPS 6-28 volts DC. Is it 75 amps or 7.5 amps? What would be a good replacement? So many to pick from it gets a little confusing. Thx
2017 Flagstaff 524RLWS
2015 F150 , 5.0 , 3:55 axle
mikdor1 is offline   Reply With Quote
Old 09-30-2017, 01:24 PM   #2
Buy a BlueSea switch. They can handle way more current as well so they are more rubust...not that you need the extra capacity.
https://www.bluesea.com/products/cat...tches/m-Series
babock is offline   Reply With Quote
Old 09-30-2017, 01:54 PM   #3
It is 75 Amps.
2017 Rockwood Windjammer 3006WK
dankirk is offline   Reply With Quote
Old 10-09-2017, 09:49 PM   #4
Mrpsyko's Avatar
I broke mine last year and found the exact replacement on Amazon. Pollak 33506 push pull switch. 75 amps 6-28 volts.
2017 Flagstaff Super Lite 26RBWS/2014 F150 XLT SCREW 5.0 V-8
https://www.forestriverforums.com/at...pic35767_3.gif
Mrpsyko is offline   Reply With Quote
Old 10-10-2017, 09:00 AM   #5
I think the number is 35306.
Pollak 35306 - Amazon $13.97
Pollak 35306 - RV Auto Parts $5.85
Pollak 35306 - Walmart $6.74
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
battery, battery disconnect, switch
